May 22, 2012, 03:48 |
can't open case in fluent 13
Michal
Rep Power: 14 |
Hello
I built 3 different meshes using Gambit. loaded the first mesh, and then attached the others to it using : mesh->zone-> append case file (found this tip on this forum somewhere) I used "mesh interfaces" to create the interface between the different meshes, saved my case, and ran calculations as usual. When I come to reopen the case, I get this error message: Error: CDR: invalid argument [1]: wrong type [not a pair] Error Object: #f Note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface. the mesh is loaded, but almost every option in the menu is blocked(including mesh interfaces), and I can't continue. What am I doing wrong? thank you |
Can i open a case file version 13 with a fluent version 12 !! | diamondx | FLUENT | 2 | February 4, 2012 08:33 |
Slow case loading on parallel fluent | jhome | Hardware | 3 | December 21, 2011 15:19 |
Executing Fluent case in OpenFOAM | Viglen1956 | OpenFOAM | 0 | June 7, 2010 06:47 |
How to open two case in paraview? | bowlderyu | OpenFOAM | 2 | June 2, 2009 04:20 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
