[GAMBIT] 3D hollow cone spray meshing problem
Old   April 11, 2012, 01:42
Question 3D hollow cone spray meshing problem
Zh
adsl17754 is on a distinguished road
Hi everyone,
I met a problem when I tried to make a 3D hollow cone spray mesh in Gambit. I meshed the top face first(shown below), and tried to use cooper to generate volume mesh, then the error "Assertion failed in FullMinMeshTool.cc, line 749: geom_children.size()==mp->..."(shown below) appeared, I tried many times but the error still exists... Hoping to get your suggestion, many thanks~
2012-04-10_HollowCone_5_1.png 2012-04-10_HollowCone_4_1.jpg 2012-04-10_HollowCone_4_2.png
adsl17754 is offline   Reply With Quote
Old   April 11, 2012, 01:58
Vinayender
vinayender is on a distinguished road
Hi
just to see there is no problem with your geometry or procedure,
try first meshing with a coarse gird and see...
look mesh is too fine at the corner
Thanks ,
Vinayender
vinayender is offline   Reply With Quote
Old   April 11, 2012, 02:18
Zh
Thanks vinayender. Try a coarse grid at first is a good suggestion, I will try it later. I am interested in how to generate volume mesh with such fine grids at the corner, because I need fine grids to insure accuracy. Many Thanks~
Old   April 13, 2012, 23:56
Zh
I found something wrong with the geometry of that face. I can now mesh the volume~
3d mesh, gambit
problem with gambit unsymmetrical meshing meenakshi FLUENT 1 March 28, 2008 13:46
Problem with hypersonic blunt cone solution Bharath Hebbal FLUENT 0 February 15, 2008 03:07
problem in meshing a periodic boundary dumas FLUENT 4 March 8, 2006 11:54
meshing hollow part of pipe rai FLUENT 0 December 19, 2005 01:46
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
