[DesignModeler] Ansys Geometry n meshing
Like Tree11Likes
Old   July 26, 2015, 00:43
Default propller domain meshing
  #81
sohrabmajd is on a distinguished road
here is my model meshing and my setting for mesh:
http://www.2shared.com/file/EKzK--6U...ject_pics.html
the places near rotating domain has bad coarse meshes that it need to fine for better results but i don't know how do it.
is there anyone to help me please?
sohrabmajd is offline   Reply With Quote
Old   July 26, 2015, 19:34
Kapi is on a distinguished road
Hi Sohrab,
I asked you to use sizing option but you havent used it it seems.
Give Edge sizing in duct, rotating domain and Propeller starting with element size of 3mm and see how the mesh turn out to be. IF you are not happy with mesh then reduce element size.
Right click on "Mesh" then Insert Sizing. Select body/face/edge where you want sizing and then give appropriate element Size
Use body sizing and Edge sizing on your model.
Use inflation as well in each body in your part.
Can I suggest you to go thru tutorials first before going ahead?
It will help you how meshing works.
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   August 24, 2015, 13:47
Pantelis
saio23 is on a distinguished road
can i have the training material also please? darthsaio@gmail.com
saio23 is offline   Reply With Quote
Old   August 24, 2015, 14:15
sifet is on a distinguished road
Yes I need if it is possible
sifetistikamet@gmail.com
sifet is offline   Reply With Quote
Old   August 24, 2015, 20:48
Hi Saio23 and Sifet,
I have sent you the training material for design modeler and Meshing both.
Please check your email.
Anyone else interested then let me know
Cheers
KAPI
Old   August 25, 2015, 06:14
Manish
msm6166 is on a distinguished road
can you please send it to me also .my email id is mishramanish1988@gmail.com
msm6166 is offline   Reply With Quote
Old   August 25, 2015, 06:21
Pantelis
Thank you Kapi for the material. Do you also have material for ICEM ?
Old   August 25, 2015, 08:56
Default Thanks
  #88
Best wishes
Old   August 25, 2015, 20:44
msm6166 - > Emailed you!
saio23 - > Emailed you
sifet - > Thanks
Old   August 26, 2015, 05:18
wanghuo
hotboy is on a distinguished road
Could you send it to me ? my email is hotboya2008@gmail.com Thank you very much!
hotboy is offline   Reply With Quote
Old   August 26, 2015, 06:23
Pantelis
Thank you very much Kapi
Old   October 2, 2015, 12:33
ColinD92 is on a distinguished road
Could someone also please send me the material? Email is colin.donaldson1@ntlworld.com
ColinD92 is offline   Reply With Quote
Old   October 3, 2015, 23:56
Ahmed Adel
aai15001 is on a distinguished road
ahmed.adel2022@gmail.com
Thanks in advance
aai15001 is offline   Reply With Quote
Old   December 11, 2015, 00:35
emailed everyone above!
Far likes this.
Old   March 16, 2016, 02:45
Chicklets@g is on a distinguished road
Cam u pls send me the tutorials on gharatkunal123@gmail.com
Chicklets@g is offline   Reply With Quote
Old   April 3, 2016, 18:35
SMN
mortazavi is on a distinguished road
hello.
may you send for me these files?
mortazavinia@gmail.com
thanks,
Originally Posted by Far View Post
Done... Any one else needs these files including CFX and Fluent tutorials
mortazavi is offline   Reply With Quote
Old   April 3, 2016, 19:24
Please specify which tutorial are you after? DM/Mesh/CFX/Fluent?
Old   April 3, 2016, 22:13
SMN
I want to simulate flow induced vibration of a hydrofoil in CFX and ansys. You as a senior member, definitely know some documentsétutorials useful for me. :-)
Old   April 3, 2016, 22:43
emailed you both Mortazavi and Chicklets@g
Old   April 5, 2016, 00:17
Thanx a lot Mak
design modeler tutorials, meshing
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 23:04
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 01:43
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 27, 2011 00:25
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
Problematic geometry in Ansys Meshing ATOTA ANSYS Meshing & Geometry 1 October 9, 2010 12:51
