[DesignModeler] Ansys Geometry n meshing
Like Tree11Likes
Old   August 20, 2014, 02:35
azadeh
mirvakili is on a distinguished road
May you send me these files? mirvakili.azadeh@gmail.com
thankyou so much
mirvakili is offline   Reply With Quote
Old   August 20, 2014, 06:23
rgd
rgd is on a distinguished road
Originally Posted by Far View Post
any body else need the training material?
Dear Far,
Could you please send me the fluent (DesignModeler) meshing tutorials, to raghda.heikal5@gmail.com
Thanks a lot in advance.
rgd is offline   Reply With Quote
Old   September 14, 2014, 02:38
Salman Adam
Salman Adam is on a distinguished road
may you send me the tutorials too??
salmanadam@gmail.com
many thanks
Salman Adam is offline   Reply With Quote
Old   October 7, 2014, 22:50
Andreas Nikolaou
an1710 is on a distinguished road
Hi, could you please send me the tutorials? a_k_nikolaou@yahoo.com
Thank you!
an1710 is offline   Reply With Quote
Old   December 10, 2014, 06:39
Amin Rahmat
aminrahmat is on a distinguished road
- anyone else
Hi Far, would it be possible to send me a copy as well? thanks.
arahmat@sabanciuniv.edu
aminrahmat is offline   Reply With Quote
Old   December 27, 2014, 01:08
Default icem lectures
  #66
Abhijit
abhiaero is on a distinguished road
helllo sir,
can u share the ICEM lectures files and training materials?plsease..!!
help appreciated..
abhiaero is offline   Reply With Quote
Old   December 27, 2014, 05:06
seputra is on a distinguished road
Hai Far,
Could you please send me the tutorial? I need it. By the way, im a newbie here , please send it to seputraparamasidi@gmail.com
Thanks and Best Regards
seputra is offline   Reply With Quote
Old   December 29, 2014, 05:35
Riyaz Ahamed S
sriyaz is on a distinguished road
Mr.Far could you please send me also the tutorial?
riyaz.ahamedgce76@gmail.com
sriyaz is offline   Reply With Quote
Old   February 26, 2015, 23:46
siti
sitisani is on a distinguished road
Hi, can someone email me the tutorials as well? Thank You
sitisani is offline   Reply With Quote
Old   February 26, 2015, 23:48
siti
Hi Far,
Can I have the tutorials as well? I really appreciate your effort. Thanks!
sitihabibah@unikl.edu.my
Old   July 10, 2015, 12:42
Milad
mizzou is on a distinguished road
May I have the tutorials too?
Thanks in advance.
milad.darzi@ut.ac.ir
mizzou is offline   Reply With Quote
Old   July 10, 2015, 23:11
wanghuo
hotboy is on a distinguished road
Dear Far!
Could you send me the tutorials about ansys meshing to me ?Thank you very much! My email is hotboya2008@gmail.com !
hotboy is offline   Reply With Quote
Old   July 12, 2015, 04:49
Default ansys meshing
  #73
sohrabmajd is on a distinguished road
hi 2 all
I'm new user of ansys that want to use ansys cfx for a ducted propeller.
i can't mesh my model as good as that my solver give me best results.
how can i mesh my model with boundary layers that have fine meshes near propeller and duct and meshes grow slowly linearly with distance from the duct?
I work with ansys workbench and fluid flow(CFX).
thanks
sohrabmajd is offline   Reply With Quote
Old   July 12, 2015, 20:56
Kapi is on a distinguished road
Hi sohrabmajd,
You need to give Mesh>Edge sizing on the propeller.
Use "Bias Type" depending on where you want coarse mesh and fine mesh.
It will help the mesh to grow coarse as it moves away from duct.
Use the Bias factor depending on how drastic you want to change mesh size with distance.
I also suggest to use "Behavior" as "Hard", this will make sure you are getting what you are feeding.
Hope it helps
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   July 15, 2015, 00:43
Default propller domain meshing with ansys meshing
  #75
Originally Posted by Kapi View Post
Hi sohrabmajd,
Hope it helps
Cheers
KAPI
Hi Kapi
nice to meet you
I did what you were told but it didn't do it
here is my model file and its pictures:
http://www.2shared.com/file/kygPxAmL/ducted_kaplan.html
I modeled a ducted prop. that had a rotating domain about propeller and a main domain as open water.
when i select rotating domain for geometry in method, it meshed fine and the domain coarse
but when i select main domain as geometry, both domain meshed fine that my laptop memory show error and in solver show not enough allocated memory.
if yo see my model, please help me to setting up ansys workbench for meshing it.
thanks so much because of your help.
Old   July 15, 2015, 20:00
Bit busy, I will have a look at your file on Tuesday.
Cheers
KAPI
Old   July 21, 2015, 03:39
  #77
Cheers
KAPI
ok
thanks Kapi
Old   July 21, 2015, 06:13
Default Tutorials
  #78
Dominik Bär
Aceo0 is on a distinguished road
Hey Far can u send me the tutorials aswell ? Thank you
baer-dominik@gmx.de
Aceo0 is offline   Reply With Quote
Old   July 21, 2015, 11:13
Pantelis
saio23 is on a distinguished road
Can i have the tutorials for Meshing too please?
darthsaio@gmail.com
saio23 is offline   Reply With Quote
Old   July 25, 2015, 14:01
Manish
msm6166 is on a distinguished road
i m also new to ansys my geometry is a complex one when i mesh it surface quality comes around 0.4 but while doing volume most of the elements r seen outside if u say i can show u the geometry and also the image after volume meshing
msm6166 is offline   Reply With Quote
design modeler tutorials, meshing
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 23:04
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 01:43
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 27, 2011 00:25
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
Problematic geometry in Ansys Meshing ATOTA ANSYS Meshing & Geometry 1 October 9, 2010 12:51
