September 29, 2012, 07:48 |
#21 |
Maryam
Rep Power: 14 |
would it be possible to send me these tutorials related to designmodeler and meshing in ANSYS. I deeply appreciate you. my address E-mail is maryam.chem86@yahoo.com
September 29, 2012, 08:02 |
#23 |
Maryam
Rep Power: 14 |
I want to create the geomtry and mesh of the system used in tutorial 20. using the eulerian multiphase model for granular flow in designmodeler and meshing in ansys workbench. is there any manual to use so that I can learn how to create them.
September 29, 2012, 08:04 |
#24 |
can you show the picture of that tut here? Which software you want to use ICEM or ANSYS meshing ?
September 29, 2012, 08:16 |
#25 |
Maryam
Rep Power: 14 |
thanks for your E-mail
i want to use ansys meshing in workbench |
September 29, 2012, 08:46 |
#26 | |
Maryam
Rep Power: 14 |
https://www.sharcnet.ca/Software/Flu..._granular.html |
September 29, 2012, 11:21 |
#27 |
upendra kumar shukla
Rep Power: 14 |
September 29, 2012, 11:23 |
#28 |
Rep Power: 14 |
Yes I also need it....upendra.shukla@iitgn.ac.in
Thanks in advance |
September 29, 2012, 11:25 |
#29 |
September 29, 2012, 11:29 |
#30 | |
Rep Power: 14 |
September 29, 2012, 11:33 |
#31 | |
Rep Power: 14 |
September 30, 2012, 18:43 |
moving heat source problem
#33 |
Rep Power: 14 |
Can fluent modeling a moving heat source on a surface using UDF fonction and how?.The heat source is a moving concentric cylindrical burner heating a solid surface. and I would like to watch the transient nature of the surrounding temperature profiles. Please help me. Can u sent me some tutorials or lecture to me on moving heat source problem.thanks in advance mail-upendra.shukla@iitgn.ac.in |
September 30, 2012, 21:01 |
#34 |
Rep Power: 14 |
mail -upendra.shukla@iitgn.ac.in
Sir please sent me the tutorial and lecture on moving heat source problems on above mail id. |
October 1, 2012, 09:20 |
#35 |
Omar
Rep Power: 15 |
October 2, 2012, 08:48 |
#36 |
idil tezcan
Rep Power: 14 |
Hello sir, I also need the tutorials, could you please them to idiltezcan@gmail.com
Thank you very much... |
November 28, 2012, 22:13 |
#37 |
Mike
Rep Power: 14 |
hi ... would you be kind to send one to my email address too? fangxiaoran@gmail.com really appreciate it!!! learning ansys/fluent right now .. still a mess!!
November 29, 2012, 02:50 |
Fluent Tutorials
#38 |
Mike Wilson
December 1, 2012, 13:26 |
#39 |
Rep Power: 14 |
I would appreciate if you could sent them to me as well.
vrubinita@hotmail.com |
design modeler tutorials, meshing |
How To save a created mesh file in Ansys Meshing | ashtonJ | CFX | 4 | January 7, 2012 23:04 |
[Other] Ansys meshing airfoil and / or compressor blades | baw192 | ANSYS Meshing & Geometry | 8 | September 23, 2011 01:43 |
Reg difficulties in meshing the geometry...Urgent | arunraj | ANSYS Meshing & Geometry | 0 | August 27, 2011 00:25 |
[ANSYS Meshing] Ansys meshing with extended meshing | jsm | ANSYS Meshing & Geometry | 6 | January 10, 2011 13:09 |
Problematic geometry in Ansys Meshing | ATOTA | ANSYS Meshing & Geometry | 1 | October 9, 2010 12:51 |
