[ICEM] Cylinder meshing tutorial
Like Tree8Likes
Old   April 12, 2012, 04:40
Mahindra
mahi007 is an unknown quantity at this point
Originally Posted by Far View Post
Delete the interior circle curves before extruding and use link edge command to make the edges of circular shape.
This procedure is defined in part I.
I tried but did not work. It seems I am going wrong at giving BCs. Please try extruding that mesh with 0.19 spacing and 32 layers.
Please give me directions to work on 3D mesh. Please its urgent.
mahi007 is offline   Reply With Quote
Old   April 12, 2012, 05:25
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Going to upload two videos (two parts for each and in total four) on youtube today. Worked on both files i.e. attached in this thread and as well as older one.
Far is offline   Reply With Quote
Old   April 12, 2012, 06:41
Far
Sijal
do you know how to mesh the connection between two cylinders properly when one small cylinder is perpendicular connected to a bigger one at the top/bottom. (picture 1 +2)
I always have bad elements where the small cylinder meets the ceiling of the bigger cylinder. (picture 3)
Is there a good way to make the connection without these bad elements or are they unavoidable respectively of low importance?
kind regards
You can use y-block for sharp corners http://www.cfd-online.com/Forums/ans...tices-why.html
Old   April 12, 2012, 06:45
Far
Sijal
This may also be helpful
http://www.cfd-online.com/Forums/ans...id-y-grid.html
Old   April 12, 2012, 15:24
Far
Sijal
@ mahi007: In response to mahi007 queries and converted 2-d cylinder (from old) to 3d cylinder.
Old 2-d files: http://www.4shared.com/rar/LRL3929E/..._complete.html
New 3d files: http://www.4shared.com/zip/_cQL4Sm6/...r_3d_mahi.html
PartI
http://www.youtube.com/my_videos_edi...id=jL2hHxpsrHQ
Part II
http://www.youtube.com/watch?v=1lRRg...ature=youtu.be
Old   April 14, 2012, 00:47
Default 2d to 3d
  #26
Far
Sijal
Refer to post #1
Procedure to convert 2d blocking and geometry into 3d blocking and geometry
2d files (same as posted on post#1) :http://www.4shared.com/zip/njICQ_NM/...thdomains.html
3d files :http://www.4shared.com/rar/A0xrmLf_/Cylinder3d.html
You tube links:
Part I :
http://www.youtube.com/my_videos_edi...id=l-Tz6MHlT1M
Part II :
http://www.youtube.com/watch?v=cWuVV...feature=relmfu
Old   April 17, 2012, 06:41
Sören
despaired student is on a distinguished road
Thanks for the hint. I've already tried Y-blocking but it's not working...
Anyway, the blocking in this geometry looks good. This is just a minor problem.
despaired student is offline   Reply With Quote
Old   April 17, 2012, 06:50
Far
Sijal
Y-block works for wedge, I am sure you know it. Post pics to identify the problem area.
Old   April 17, 2012, 07:44
Sören
Here is one picture and I also added the .tin + prj. + blk. + .fbc files. When you apply the quality-criterion Det 3x3x3 at the pre-mesh you will see the region with the bad elements.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 4 October 19, 2010 17:45
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 0 October 9, 2010 22:56
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Meshing spheres in a cylinder Jesse FLUENT 3 November 23, 2005 22:03
