[GAMBIT] Gambit - Problem having shadow wall on volume
Old   March 21, 2012, 20:53
Default Gambit - Problem having shadow wall on volume
Edward Overy Jr.
ejvikings is on a distinguished road
I've constructed a 3d file in gambit to model heat and mass transfer from a leaf. I have a rectangular volume made and i made a volume inside the rectangular volume to be the leaf.
After meshing the inside the leaf volume with hex/wedge cooper and the rectangular volume using hex map, specifying the zones and exporting it to fluent, under boundary conditions, there is just leaf, there is no leaf_surface which I need for some user defined functions.
What do I need to change in gambit so that I can get the leaf to have the leaf shadow as well?
ejvikings is offline   Reply With Quote
Old   March 22, 2012, 07:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you need to split or substract.
Post a picture or a sketch
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 22, 2012, 16:19
Edward Overy Jr.
http://imageshack.us/photo/my-images/138/leaf3d2.png/
There's the picture of the gambit file before I meshed bot the inside of the leaf volume and then the overall volume. I tried subtracting the leaf volume from the rectangular volume, but then it won't mesh using the same hex method.
Old   March 23, 2012, 02:30
-mAx-'s Avatar
Maxime Perelli
ok then if you substract the leaf from the rectangular volume, and you cannot mesh the volume with hex anymore, that means you are on the right way.
Thus you cannot mesh non-basic volume with hex automatically.
You need to split your volume, into smaller volumes, which will be hex- meshable
gambit, mesh, problem, shadow, wall
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Having problem in creating a volume mech in GAMBIT Jake FLUENT 1 April 25, 2008 06:01
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
