[DesignModeler] Bubble column / Airlift Reactor with separate headspace
Old   March 21, 2012, 05:30
Default Bubble column / Airlift Reactor with separate headspace
Kevin
kevinlipps is on a distinguished road
Hi Everybody,
I have a little beginners Problem using the Designmodeler...
I want to simulate an airlift reactor with some special baffles and since I read already a couple of times that a separate headspace filled with only air from the beginning is better if using FLUENT I want to create two cell zones, a lower one with containing water and a small one on top filled with air.
When I draw my bubble column I used already many different planes, but the "Surfaces from Sketches" generates me just one single 2D body where I need two... even if I use the button twice, once for the lower part and a second time for the upper sketch separately... there will be just one surface body combining the two as one.
I thought about slicing via a rectangular body in the ZX-Plane.. but I dont really know how to do it... all I want is to separate the surface body into two bodies of which edges superimpose so I can export them to the Meshing App and be able to choose a coarser grid for the air filled headspace.
kevinlipps is offline   Reply With Quote
Old   March 21, 2012, 08:56
Raja_Bhai
tauqirnawaz is on a distinguished road
You do not need to create a body to slice, simply create a plane at desired location and use it to slice.
tauqirnawaz is offline   Reply With Quote
bubble column, designmodeler, headspace, two cells, two phase
Bubble Column Modelling dlaw FLUENT 24 October 31, 2017 07:01
bubble column ken FLUENT 1 June 30, 2013 02:18
Modelling a Water-Air bubble column GerhardHolzinger OpenFOAM Running, Solving & CFD 1 February 28, 2012 05:12
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 09:59
Help required for CFD simulation of Trayed Bubble Column using Fluent art705 Main CFD Forum 0 July 15, 2009 05:04
