[ANSYS Meshing] Bias and Bias Factor
Old   March 20, 2012, 11:17
Default Bias and Bias Factor
Ali
Hybrid is on a distinguished road
What is Bias factor in Ansys Meshing? How it is computed and applied?
Any comparison to bunching law in ICEM?
How to copy distribution to parallel edges in Ansys meshing?
Please help?
Best Regards
Ali
Hybrid is offline   Reply With Quote
Old   March 20, 2012, 12:00
Raja_Bhai
tauqirnawaz is on a distinguished road
This is a bit similar to bunching law in ICEM but with only four options. You need to specify settings as below
The mesh generated would look like below;
tauqirnawaz is offline   Reply With Quote
Old   March 21, 2012, 02:36
Ali
Thanks for your reply.
I know it how to apply but I need its computation in a sense to adjust spacing on two adjacent edges.
If I specify 100 divisions to an edge with bias factor of 10 and the adjacent edge to same divisions and bias factor the spacing is different, keeping in mind that both the edges have different lengths.
How to do so?
Best Regards
Ali
Old   March 21, 2012, 03:59
Raja_Bhai
How to do so?
Ali,
it would be more specific if you can send screen print of your problem.
By the way did you try "Element size" instead of number of divisions?
Old   March 21, 2012, 13:21
Default Tetra issue: How to tackle?
Ali
Kindly suggest how to resolve the issue?
Best Regards
Ali
Old   March 22, 2012, 04:39
Raja_Bhai
1. make transition as "SLOW"
2. Use a growth rate of "1.1"
Old   March 26, 2012, 13:37
Ali
There is no transition tab in the panel, what to do?
Best Regards
Ali
Old   April 19, 2017, 00:56
Mehak
Mehakkar is on a distinguished road
Similar problem i had also in generating the mesh around the airfoil.
Sent from my ASUS_Z00LD using CFD Online Forum mobile app
Mehakkar is offline   Reply With Quote
[ANSYS Meshing] edge sizing control--Calculate cell-to-cell expansion rate from bias factor la7low ANSYS Meshing & Geometry 6 December 19, 2021 07:49
bias mesh kbasnet ANSYS Meshing & Geometry 1 March 2, 2011 21:52
