March 16, 2012, 15:26 |
Meshing complex geometry
andres
Rep Power: 16 |
Hi everyone
I am struggling to mesh a complex geometry. I have tried almost everything without success, I would appreciate if some of you could give me a hand on it Attach you will find such a model Any idea about how to approach this problem? this is a domain of a fluid. Thanks |
March 19, 2012, 09:49 |
#2 | |
Raja_Bhai
Rep Power: 14 |
March 19, 2012, 09:59 |
andres
Rep Power: 16 |
Thanks for you quick response.
This site doesn't allow to upload a 3MB file. Could you please give me your email so i can send to you? you can email me at andres.rperez@hotmail.com Thanks again |
March 19, 2012, 10:13 |
#4 | |
Raja_Bhai
Rep Power: 14 |
March 19, 2012, 10:14 |
andres
Rep Power: 16 |
I tried everything... not only quad mesh... just everything and nothing worked...
I will check my email |
March 19, 2012, 10:17 |
andres
Rep Power: 16 |
still waiting... no new emails yet
March 19, 2012, 10:28 |
andres
Rep Power: 16 |
Could you please send an email again?
March 19, 2012, 10:29 |
andres
Rep Power: 16 |
fine! I got it!
March 19, 2012, 23:37 |
#9 |
Sarang Dalne
Rep Power: 16 |
can you send geometry to sarang.dalne@gmail.com?
What type of analysis you want to perform on this model? This will drive what type of mesh to be used. Did you try thin sweep with this model? I guess you have to try mixing couple of methods to get the desired mesh quality here. |
March 20, 2012, 04:31 |
#10 | |
Raja_Bhai
Rep Power: 14 |
Have just checked the IGES file sent by you. One quick issue is that you did create the hydraulic model in a way that some additional solid bodies were also created. You need to suppress the solid bodies in solidworks or you can bring in the solid geometry in WorkBench and create hydraulic model by fill tool. If you just want to continue with the iges file that you have sent to me then suppress all the bodies in DM except the first one. Then try refined mesh using curvature as advanced sizing Function and defining appropriate sizing criteria. |
March 20, 2012, 19:59 |
convergence
#11 |
andres
Rep Power: 16 |
Thanks I will try to do that. But with IGES file no problems were found.
However I have a problem with convergence I am studying a transient state study (unsteady). The first iteration is correct and it achieves a perfect convergence but, the second one... it doesn't converge at all that's the problem?? is there anything I would change? I decreased the time step to 1E-05 but it didn't converge whatsoever any idea?? thank you |
March 21, 2012, 04:06 |
#12 |
Raja_Bhai
Rep Power: 14 |
This is because of the mesh, you need to refine it and before that delete the bodies except the first, otherwise the mesher creates two meshes on same part.
March 21, 2012, 09:24 |
#13 |
andres
Rep Power: 16 |
but actually I modified the model and I don't have 8 bodies anymore but just one.
I am going to refine the mesh anyway. However if I refine it I will get smaller cells which will decrease my time step right? I am working with a 0.00001 time step... if I use lower values it going to take forever to simulate 1 second simulation! any suggestions? thanks |
April 27, 2017, 05:03 |
#14 |
Xant
Rep Power: 10 |
Hi everyone
i am working on a CHT-simulation with fluent and got big Problems with the meshing. There are one Fluid-Domain und one Solid Domain, which generate heat. I have tried to clean up the geometry as much as possible. Has anybody idea? Best regards Xl 1.png 1_1.png 1_2.png 1_3.png Attachment 55625 |
May 4, 2017, 11:09 |
Newbie
#16 |
Hello, I am having some problems with meshing Francis turbine. I am using Fluent and I defined 4 bodies (Inlet(spiral casing), Stator, Rotor and Outlet). First, I tried the PCM(Automatic Method) and it was fine but when I tried to simulate the turbine an error occured, saying that "Divergence detected in amg solver epsilon"(I was using k-epsilon method). So I decided to refine a mesh but geometry is pretty complex so I dont know which meshing method to use. I think Sweep and Multizone are hard to get, what do you think? Any advice?
P.S. I tried to Merge faces/bodies but then my geometry changes a lot PPS If its necessary I can post .step file |
Complex .stl data for volume meshing in ICEM CFD | Nils_H | ANSYS Meshing & Geometry | 5 | September 2, 2011 09:39 |
Need help on meshing this simple geometry | nha1g08 | ANSYS Meshing & Geometry | 3 | March 9, 2011 03:13 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
IGES/IGS format geometry file for icem meshing | littlelz | Main CFD Forum | 0 | May 27, 2008 19:24 |
Creating geometry & meshing using Gambit | Ray | FLUENT | 3 | August 1, 2000 04:30 |
