[ANSYS Meshing] steady-state thermal analysis in ansys workbench
Old   March 15, 2012, 10:02
Default steady-state thermal analysis in ansys workbench
choirul mutamam
zenwalk is on a distinguished road
someone help me, i have assignment to analysis heat loss from brick kiln. how to analysis with ansys? i have tried in ansys workbench (steady-state thermal analysis) but i cannot how to mesh and setup )step by step). i have geometry file in (*.sat) file extention. please help me to solve my project......
this is geometry file or here
zenwalk is offline   Reply With Quote
Old   March 16, 2012, 14:15
Sarang Dalne
sarangdalne is on a distinguished road
Which ANSYS version are you using? I was able to create the mesh on your geometry within couple of secs and with default mesh settings.
When the meshing process fails there are good error messages given. Use them as guidelines.
By the way what errors are you getting?
sarangdalne is offline   Reply With Quote
Old   March 19, 2012, 21:53
choirul mutamam
i use ansys 12.1 version 64 bit, can you help me to explain every mesh methode, please help me sir.
Old   March 19, 2012, 22:40
Sarang Dalne
There is very good documentation available in ANSYS help. You can search by the methods. Let me know if you need specific detail about any particular method. I can't explain every method here
I guess you will be better using patch conforming for the geometry you have and for the analysis you are using.
You can play around with relevance: make it higher around 100.
make "Relevance Center:" use fine or medium.
If this doesn't work then try using "On Fixed" advanced size function.
ansys, steady state, thermal analysis, thermal conductivity, workbench 12
FSI Transient Thermal Analysis Abduri CFX 1 January 1, 2017 23:54
tutorial for CFD & modal (acoustic) analysis ansys workbench 11 badterojan ANSYS 1 June 18, 2009 11:29
Steady State 2 phase problem fivos FLUENT 0 April 27, 2009 17:34
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
