March 12, 2012, 08:00 |
Newbie - Create Region
Rodrigo Vernini
Rep Power: 14 |
Hi, i'm modeling a ultrasonic sensor, because of it's complexity and my affinity with solidworks i decided to design it in solidworks and import to ansys simulation - version 11 (that's installed in the university PC).
I need to make it work in an air region. I saw the function to create a region in the modeler, and i use it when simulating in MAXWELL 3D, but in the simulation screen i can't define the region. Than i tried to make it in solidworks, creating a part to make it air material, but i need to create a part in the complex area inside and outside the sensor, and i think it's not the easiest way. And all the modification i'll make in the construction i have to make it in this region part. Than i tried to import the solidworks construction in the modeler instead of the simulation, but i got an error "Geometry interface not found", i saw in the forum that's a license issue. Someone know a simple way to solve my problem? Thanks! |
March 12, 2012, 12:15 |
Rodrigo Vernini
Rep Power: 14 |
Ok,
no one replied. Don't know if it's because my poor english, the lack of information, or , propably the to newbie question. The product i'm trying to design is a piezoelectric sensor that must get information about the vibration of a pipe around 40kHz, the vibration will pass through a waveguide that is in touch with the pipe, and will vibrate the air inside a small area inside the product, that contains the piezoelectric sensor. I need to design the product so i maximize the sensibility in the piezoelectric. I was trying to make this simulation with "modal analysis" but i don't know if a must use CFX or fluent, or any other, because i need that FSI between waveguide-air-piezoelectric. Please help me, any information will save me a lot of time. |
March 12, 2012, 13:15 |
Rodrigo Vernini
Rep Power: 14 |
Create Region Solved.
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
multi region case - access field from another region | mabinty | OpenFOAM Programming & Development | 3 | September 6, 2011 10:25 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
[GAMBIT] Periodic BC | truffaldino | ANSYS Meshing & Geometry | 4 | June 5, 2011 06:39 |
reconstructpar -region | borrbyper | OpenFOAM Bugs | 2 | April 23, 2009 13:52 |
