August 9, 2013, 11:10 |
#62 |
Rep Power: 13 |
Hi Far,
I scratch my head on for a while on that geometry. Finally I was able to reach a quality > 0.25 - 0.3 On the tail on the wing section I recreate your blocking strategy (two blocks tangent to for a diamond) and than I select each faces of them and under edit block --> convert block type --> I chose type Y block and in the image attached you can see how it looks like If anyone has other advices how to improve the quality, I attach the .blk and .tin files if you want to see (I reckon my blocking is a bit ..messy ) |
December 22, 2013, 05:24 |
#63 | |
Meimei Wang
Rep Power: 16 |
I also tried to generate the mesh in this way. But the problem is the trailing edge angle for my airfoil is lower than 18 degrees (I model the airfoil NACA 2412). So even though you use the Y-block, you still have the smallest grids angle lower than 18 degree. Any thought about this trailing edge angle constraint? How to solve this problem without introducing GGI?
Best regards, Meimei |
December 22, 2013, 06:01 |
#64 | |
February 3, 2014, 10:59 |
#65 |
Meimei Wang
Rep Power: 16 |
What do you mean by free type? Unstructured grids?
February 3, 2014, 11:08 |
#67 | |
Meimei Wang
Rep Power: 16 |
Another way to solve this problem is to round the very tiny small trailing edge tip. It is widely known in the airfoil aerodynamics that rounding of trailing edge tip slightly won't change its performance and the flow. And also there is manufacturing tolerance. So it can't be perfectly sharp naturally.
February 4, 2014, 04:44 |
#69 |
Meimei Wang
Rep Power: 16 |
Yes. Sharp angles can be manufactured. But the radius of the sharp trailing edge will still naturally exist (like 0.01 mm or even smaller). We can just use that tiny radius in CFD. Then we won't have to model the sharp angles and use Y block anymore even though our grids at the trailing edge might have to be very small to capture the radius. But we won't run into any grids quality problem any more. This also reduces the grids generation complexity.
May 31, 2016, 04:02 |
winglet mesh problem
#70 |
mohammadreza
Rep Power: 11 |
hi
I tried to generate mesh around wing with winglet in ICEM but after generating mesh the quality of mesh is very low and I give some error in fluent. 3 pictures are attached. Hope any of you can give me an advice for a better blocking strategy or any other suggestion is welcomed. http://uupload.ir/files/92i4_1.jpg http://uupload.ir/files/r4bh_2.jpg http://uupload.ir/files/nd2n_3.jpg Last edited by mrh111; June 3, 2016 at 04:13. |
May 31, 2016, 18:14 |
#71 |
B.H.
Rep Power: 11 |
Hi mrh111, there doesn't seem to be any attached pictures or files.
June 3, 2016, 04:14 |
#72 |
mohammadreza
Rep Power: 11 |
is that fixed?
June 3, 2016, 16:19 |
#73 |
B.H.
Rep Power: 11 |
Yes it did!
Ok so I can't tell much from the pictures; nothing is really standing out that would cause errors. It looks like you used an O-grid for the wing, but how did you transition from the wing to the winglet using the O-grid? If I can to guess, it would be that your problem is occurring at the intersection of the winglet and the wing. It is possible to create an O-grid in an "L" shape, which might work better for you. If you want, you can post your file and I'll look at it over the weekend. |
June 5, 2016, 05:10 |
#74 | |
mohammadreza
Rep Power: 11 |
http://up.persianscript.ir/uploads2/...-winglet-6.rar actually i guess i fixed the "L" shape problem. but the quality of mesh is still low and i get some error in FLUENT. http://up.persianscript.ir/uploads2/...-winglet-7.rar http://up.persianscript.ir/uploadsmedia/75f0-44444.jpg http://up.persianscript.ir/uploadsmedia/75f0-55555.jpg Last edited by mrh111; June 5, 2016 at 07:40. |
June 6, 2016, 12:34 |
#75 |
B.H.
Rep Power: 11 |
Hi mrh111,
I took a look at your file. Great job with using the O-grid on the winglet. I did find two problems, however. First, there is an association problem with one of the blocks on the bottom side of the wing near the winglet. See the first attached image. This is very likely causing some or all of your Fluent errors. Secondly, as can be seen in the second attached image, the cells right of the wing have quite a large aspect ratio. I would consider refining them for best performance. In case you didn't already know, you can find "Scan Planes" in the drop down menu when you right click on the "Pre-Mesh" item under "Blocking". It is very, very helpful when working with structured meshes and blocking. Hope this helps, and good luck! -Ben |
July 4, 2016, 16:55 |
#77 |
to complete the thread, please see this new part with new method to mesh same geometry.
https://www.youtube.com/watch?v=UO8RJWsIV40 |
July 12, 2017, 22:52 |
#78 |
dario
Rep Power: 9 |
Hallo,
I tried to follow this tutorial, but when I try to compute the mesh I have the following error: Running hexa-dominant mesher... {expecting 2 shells on edge 18 14 found 4 } error orienting normals, perhaps there is more than one region error in output_boundaries Hex Dominant meshing failed Could you please check my files? files --> https://drive.google.com/open?id=0B0...3RFdmV5TzJ5Wk0 Thanks SOLVED Last edited by dariodario32; July 13, 2017 at 20:33. |
blocking strategy, icem cfd airfoil geometry |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/ansys-meshing/98390-structured-hexa-mesh-wing.html
Posted By | For | Type | Date | |
ICEM Hexa meshing tutorial - Wing with sharp trailing edge | This thread | Refback | October 18, 2013 03:30 |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
Exporting structured mesh from ICEMCFD to Fluent? | jeevan kumar | FLUENT | 1 | January 23, 2012 11:21 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Highly skewed and inverted volumes in wing mesh | makaero | FLUENT | 0 | December 8, 2009 19:32 |
Structured Grid Definition | craig shores | Main CFD Forum | 3 | March 21, 2001 14:48 |
