June 21, 2012, 15:25 |
#41 |
Rep Power: 20 |
Ali you are a great man, Thanks alot for this. Theoretically I have fully understood the procedure but practically I do not know how to perform step no. 2 and step no.4 i.e how to insert Ogrid inside block?please explain its procedure and how to transform a block behind wing into Yblock?also explain its procedure
June 21, 2012, 15:38 |
#43 |
Rep Power: 20 |
Thanks alot Ali once again for your hardwork. So from your post what i get is that "for creating ogrid inside block we don't have to select any face and we don't have to check "Around" option". right? secondly this Ogrid will also be inserted in the tip block?
June 21, 2012, 15:42 |
#44 |
Ghazlani M. Ali
Rep Power: 29 |
no you don't have to select around. sorry my mistake, about faces yes , in our case you should select the face in FF and SYM. i guess you know the impact of selecting faces when creating ogrid. what do you mean by tip block, the block next to trailing edge ? you will transform it in ygrid
June 21, 2012, 15:49 |
#45 |
Rep Power: 20 |
NO I do-not know the impact of selecting faces while creating Ogrid and that's where I am facing problem, please explain this point and which faces exactly we will have to select in our case? by tip block I mean the block in the wing tip region not in the trailing edge region(the block adjacent to wing block in the z-direction, hope you got it?)
June 21, 2012, 15:55 |
#46 |
Ghazlani M. Ali
Rep Power: 29 |
here is a video of far explaining what happens when you create ogrid and select faces:
http://www.youtube.com/watch?feature...&v=dHfAe_6weZE Just open a new project, create a box and apply have fun with it. For the tip block you will do exactly like the block in the tip exactly same. |
June 21, 2012, 16:03 |
#47 |
Rep Power: 20 |
I have watched this video before, by selecting two faces while creating Ogrid results in Half Ogrid or Cgrid...that's what i get from this and in our case three faces will be selected for creating Ogrid, one on the symmetry plane, one inside wing tip and one in the farfield parallel to the previous selected faces. right?
June 21, 2012, 16:06 |
#48 |
Ghazlani M. Ali
Rep Power: 29 |
i just selected two face, in in the farfield and sym. I don't know the effect of selecting the face in the wing tip. i guess nothing will change. but anyway yes this is how is it .
June 21, 2012, 20:38 |
#49 |
Rep Power: 20 |
last few things Ali.....how Ogrid will be inserted at the leading edge?its Ogrid inside or Ogrid around wing and tip blocks?in this Ogrid faces will be selected or not?? and after splitting the block near trtailing edge which you marked ny pink color, the trailing edge block will be converted to Yblock.right?? the block behind trailing edge is already merged previously.right??.
June 21, 2012, 21:20 |
#50 | ||||
Ghazlani M. Ali
Rep Power: 29 |
June 22, 2012, 02:09 |
#51 |
June 22, 2012, 02:13 |
#52 |
June 22, 2012, 11:27 |
#53 |
Rep Power: 20 |
Far have you seen my blocking files? where I am going wrong by your method?
June 24, 2012, 09:47 |
#54 |
Rep Power: 20 |
helloooooooooo Far................
August 14, 2012, 16:58 |
#55 | |
venkatesh
Rep Power: 14 |
Hi diamondx, I have a question. I have low quality angle if I Insert Y-block at the tip of the cambered wing. Is there any way to increase the angle quality. |
August 14, 2012, 17:03 |
Y-grid
#56 |
venkatesh
Rep Power: 14 |
Hi diamondx,
August 2, 2013, 09:06 |
#58 |
Rep Power: 13 |
I was trying to replicate method5 of Far, but I'm not able to mesh properly my geometry that has a much more sharper trailing edge than the one in the example.
I attach .tin, .project and .blk files if someone can have a look and please give me some suggestion. Many thanks |
August 2, 2013, 12:34 |
#59 |
Either go with prism mesh or create tetra mesh in tip region.
For first option, you already have penta 6 elements, when you merged vertices at trailing edge. For second option : Edit block > convert block type > Set type and choose the appropriate option from dropdown box. I would be interested in second option as inner angle is too low. PS: You can also trim trailing edge to have better mesh. Moreover practically it is not possible to manufacture such sharp angles due to limitations of tools and machines used in process. |
August 5, 2013, 10:20 |
#60 |
Rep Power: 13 |
Thank you Far
blocking strategy, icem cfd airfoil geometry |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/ansys-meshing/98390-structured-hexa-mesh-wing.html
Posted By | For | Type | Date | |
ICEM Hexa meshing tutorial - Wing with sharp trailing edge | This thread | Refback | October 18, 2013 03:30 |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
Exporting structured mesh from ICEMCFD to Fluent? | jeevan kumar | FLUENT | 1 | January 23, 2012 11:21 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Highly skewed and inverted volumes in wing mesh | makaero | FLUENT | 0 | December 8, 2009 19:32 |
Structured Grid Definition | craig shores | Main CFD Forum | 3 | March 21, 2001 14:48 |
