[ICEM] Structured Hexa Mesh on Wing
Like Tree12Likes
Old   March 23, 2012, 06:47
Default Quality
  #21
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Quality is good enough (min 0.64) and can be improved further by adjusting the blocking.
Far is offline   Reply With Quote
Old   March 23, 2012, 08:34
Default Method2_Modified
  #22
Far
Sijal
There is little modification in method 2 >>>> Method 2 - Modified
Instead of O-Block in the tip region in leading edge block, this time I have used C-topology(selecting two rear edges).
Old   March 23, 2012, 15:50
Default Method 3
  #23
Far
Sijal
Method 3
Y-blocking is not needed for this topology scheme.
Blocked collapse or node merge was not used.
O-grid is created around wing and inside wing tip block. See attached files and Pics.
Old   March 27, 2012, 05:46
cfd seeker is on a distinguished road
Far thank you very much for taking out time and doing this stuff for me but as I have told you I have no experience at all in blocking strategies. If you can create a tutorial or at least a word document narrating the steps for creating the blocks and setting the mesh parameters then it will really help me and I shall be very thankful to you for this. I know I am asking for a bit more but as I have already told you that I have no experience at all in this and no one around me knows about this. Thanks in advance.
cfd seeker is offline   Reply With Quote
Old   March 29, 2012, 10:16
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Thanks Far for all your hard work on this one... I have been busy at work lately, and working long hours.
There are several ways to handle a 3D wing. This one's key features are a sharp trailing edge (which suggests a C Grid) and a flat wing tip, which is most easily captured with (Blocking => Create => 2D to 3D).
Start with a 2D blocking... But because you will need to keep the flow volume past your wing tip, you also need to mesh inside the airfoil. The topology Far showed works well, or if you can handle wedges in your model, you could just keep the very simple collapsed block you got from collapsing the blocks behind the trailing edge, then add the Ogrid to the front inner block of the airfoil.
Then go to Create Blocks => 2D to 3D and choose the "by translation" option. Put in the width of your box and apply.
Then go and "delete" the blocks that should end up inside the airfoil (or put then in a solid blocking material).
Associate all the edges with the 3D curves, set up edge parameters, etc.
Done.
Far likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 18, 2012, 16:55
Far
Sijal
http://www.youtube.com/watch?v=mgjRT...ature=youtu.be
studen and inspiron like this.
Old   June 11, 2012, 07:06
Far kindly explain the method-2 in detail, i want to know how you have split- ed the wing tip block and inserted O-grid at leading edge and Y-block at trailing edge?? by which method you have inserted Y-block at the trailing edge?? and you have split-ed the main block in method-2 as you have explained in your video tutorial....am i right??
Old   June 11, 2012, 07:18
Far
Sijal
first split tip block (across all other blocks as well) and then
1. For leading edge block >>> go to oblock panel and insert the oblock and select two faces parallel to tip face.
2. For trailing edge block >>>> go to edit block and convert into Y-block.
Yes
Old   June 11, 2012, 15:30
Far
Sijal
Finally, I concluded that for wing with sharp trailing edge, the best domain is circular (hemisphere in 3d) shape at inlet and rectangular at outlet (cylinder)
Old   June 12, 2012, 03:03
I am still confused how to implement the method no.2, I am going to explain my understanding, kindly direct me where i will be wrong.
Method 2-O-grid around leading edge and Y-grid in the trailing edge
after splitting the main block using 2 points near the leading edge,edge to curve association fallowed by O-grid only around the wing(not around the wing tip block...am i right here?), then the block split behind the trailing edge fallowed by tip block split into leading edge and trailing edge blocks(where to split the tip block? at half chord?) and finally O-grid around leading edge block and Y-block around trailing edge block.
Few more questions......
1. In the tip region, Ogrid willbe created in the block or around the block?
2. Y-block will be inserted using vertex merge method or what method?
3. You said split the tip block across all other blocks....by "across all other blocks" you mean the block passing inside the wing also?
blgypeng likes this.
Old   June 12, 2012, 15:39
anyone please..........
Old   June 13, 2012, 04:13
I have almost learned the method 2 expect few steps...after splitting the tip block if the O-grid around the leading edge will be inserted then why we need to select the faces parallel to tip block? or I may be wrong here?? if yes then kindly direct me?
Old   June 13, 2012, 04:55
Far
Sijal
can you post the last few steps of your working? Where are you stuck up?
Also post .blk and .tin file.
Old   June 14, 2012, 07:17
My case is a bit different from the Naca 0015 wing case. Wing is not symmetric rather its cambered, so I decided to use method no.2 for blocking the geometry(O-grid around the block and Y-block in the tip block in the vicinity of trailing edge and O-block in the vicinity of leading edge).
I am explaining my effort in few steps so that you can figure out my mistake.....
1. 3D blocking, splitted the main block using the 2 points near the leading edge.
2. Necessary edge to curve association and vertex moved to form the block inside wing
3. Collapsed the block behind the trailing edge and vertex moved to fit the block inside wing
4. O-grid around the wing and tip block(0.1m block using absolute checked on)
5. Splitted the tip block(across the block inside wing) near the trailing edge
The work till step 5 is attached in post with the name "wing_hexa"
After this I am stucked up, I am trying to insert O-grid around the leading edge block(wing and tip block both) but not getting the blocking like as you did.
My wrong effort is attached in the post with name "wing_hexa_wrong"
I WANT TO KNOW....how you got the rounded block all around the wing and tip block and how you fitted the Y-block in the tip near trailing edge
Thanks in advance
Regards
Old   June 15, 2012, 07:15
have you seen my blocking files???
Old   June 21, 2012, 13:35
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Your blocking was very confusing there were a lot of blocks. i couldn't follow it. When i get lost like that. i erase and redo everything. maybe you are in hurry to start simulation. i made a blocking for you. take a look at it. while simulating, you can come back to geometry and analyse what was wrong.
starting by initializing a block, splitting around airfoil.
then i create an o-grid inside that split, collapsed the block by merging vertices.
next split again the o-grid around your airfoil. you will then have two zones, one for leading edge and trailing edge. it is better to start by a small o-grid inside the leading edge, then you create the Y-grid for the trailing edge. after that come another y-grid for behind the airfoil. then you adjust vertices to get good quality
Far likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 21, 2012, 16:03
diamondx's Avatar
Ghazlani M. Ali
ok as i understood, when you splitted the main block, you directly performed association ?
NO, when you split the main block, the new block you get shouldn't be associated to the wing, you have to split it one more time into another o'grid. then you will associate with the wing. don't think about splitting AROUND. you got it ?
Regards,
Ali
Old   June 21, 2012, 16:06
Thanx Ali....i have a question
1. After the initial split, we will create Ogrid inside the wing block and tip block(tip block is the block extending from the tip in the z-direction) or we will create Ogrid around wing block and tip block? I am considering Ogrid inside block and around block are different things, am I right? Please explain this point in detail
Old   June 21, 2012, 16:14
oh you replied before me i just noticed it
yes exactly after the initial split i associated the edges to curves to get the block inside the wing...tell me what i have to do instead?? and you are talking about "you have to split it one more time into another o'grid"...I am not getting this, please explain it in more detail....I guess this is my problem where I am stuck up....
Old   June 21, 2012, 16:16
diamondx's Avatar
Ghazlani M. Ali
INSIDE.look at the picture below. the initial block gave the block in red.
After that i created an ogrid inside , which is the green one. i then applied association.
after that i splitted vertically, which is purple line.
then i created another ogrid INSIDE, which is orange.
Then finally transformed the block behind in ygrid
Regards,
Ali
blocking strategy, icem cfd airfoil geometry
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/ansys-meshing/98390-structured-hexa-mesh-wing.html
Posted By For Type Date
ICEM Hexa meshing tutorial - Wing with sharp trailing edge This thread Refback October 18, 2013 04:30
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 03:33
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 12:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Highly skewed and inverted volumes in wing mesh makaero FLUENT 0 December 8, 2009 20:32
Structured Grid Definition craig shores Main CFD Forum 3 March 21, 2001 15:48
