[DesignModeler] Creating a blunt trailing edge from collapsed leading edge
Old   March 2, 2012, 10:48
Default Creating a blunt trailing edge from sharp trailing edge
gmd
gmd is on a distinguished road
Hi all,
Just a quick question. I need to edit the point geometry of the NREL s809 wind turbine blade such that it will have a (small) blunt trailing edge instead of a sharp one in order to model vortex shedding at really high angle of attack. Having a sharp TE also constantly interferes with the meshing.
I have tried to cut it using autocad but have run into problems trying to export the point data afterwards. Attempts to simply edit the point data such that the TE is blunted have also failed to produce useable results.
Is there a better and more accurate way to do this? Any help would be greatly appreciated.
Thanks!
EDIT: Noticed a mistake in the title. I meant creating a blunt trailing edge from collapsed TRAILING edge...not leading. Apologies
gmd is offline   Reply With Quote
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 11:42
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 16:19
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 13:45
