[ICEM] Help for symmetry and periodicity conditions
Old   March 1, 2012, 10:36
Default Help for symmetry and periodicity conditions
Sergio Macchiavello
OneDotThree is on a distinguished road
I need some help...
I've to represent in ICEM a volume (the section is in the figure below)
Is it possible to represent only 1/8 (in red) of the volume to do simulation? if it is, which boundary condition I have to set? symmetry? periodicity or both?
If it isn't possible I think I have to represent 1/4 of the volume (in green) and I have to set periodicity conditions, is it correct?
Thanks...
OneDotThree is offline   Reply With Quote
Old   March 1, 2012, 12:41
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
No, 1/8 is not enough. You need symmetry condition.
1/4 volume and symmetry condition.
Far is offline   Reply With Quote
Old   March 1, 2012, 12:53
Sergio Macchiavello
Thanks a lot Far
Old   March 1, 2012, 16:19
Far
Sijal
Although I believe that the periodic condition is not suitable for this model, but you should use both conditions and check accuracy of both conditions.
Old   March 2, 2012, 22:59
Erik
evcelica is on a distinguished road
What type of symmetry you can use depends on what your actually modeling, if its non-buoyant flow through this cross section you can use 1/8 symmetry. If its buoyant flow through this cross section you can only use half symmetry. But you haven't told us what you are modeling, you've only shown the shape.
evcelica is offline   Reply With Quote
Old   March 3, 2012, 01:55
Far
Sijal
well 1/8 is not possible as evident from the attached pic at post # 1
Old   March 3, 2012, 09:50
Sergio Macchiavello
The fluid is gas, in particular a CH4/H2 mixture. I can't understand why it depends on the type of fluid.
Could you give me some more explanations? Thanks a lot
Old   March 3, 2012, 09:53
Sergio Macchiavello
In any case, I think I will semplify the section to a circular one and represent only 1/8 of the whole because I can't afford to increase the cell number...
Old   March 3, 2012, 10:02
Far
Sijal
Then you must assess the error incurred due to this assumption!!!! Also compare the accuracy vs. computational cost.
In case of 1/8 model you must use periodic condition
Old   March 7, 2012, 04:49
Christoph
energy382 is on a distinguished road
i completely agree with this conclusion! it's highly questionable to put the 1/8 model.
energy382 is offline   Reply With Quote
Old   March 7, 2012, 05:28
Sergio Macchiavello
The section I've posted above is very large in comparison to the other complex volumes in it. So I'm not so interested in what happens at the external boundaries. It's for this reason that I'm thinking to semplify the geometry.
Boundary Condition: Antisymmetric periodicity Jacob Jensen OpenFOAM 4 December 2, 2014 04:29
[ICEM] ICEM periodicity specification robboflea ANSYS Meshing & Geometry 18 November 11, 2014 15:51
Difference between periodicity and symmetry boundary conditions lost.identity Main CFD Forum 9 August 30, 2012 12:16
Periodicity lost during quater ogrid blocking syler3321 ANSYS Meshing & Geometry 0 October 18, 2011 00:24
Periodicity in CFX Sam S CFX 2 August 27, 2007 01:59
