[ICEM] hex meshing volute
Like Tree18Likes
Old   February 28, 2012, 05:26
Default hex meshing volute
Christoph
energy382 is on a distinguished road
Hey guys,
is there anyone, who has already meshed a volute (turbine) and give me some advice what's the best blocking approach?
I've meshed the turbine wheel (mixed flow turbine) with ICEM Hexa so far.
Thx in advance!
n0ukh3z007 likes this.
energy382 is offline   Reply With Quote
Old   February 29, 2012, 05:04
Christoph
what about this blocking? any other suggestions or improvements?
Old   February 29, 2012, 05:05
Christoph
sequel to previous posting
Old   February 29, 2012, 15:49
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.youtube.com/watch?v=jsHDi...eature=related
anand32 likes this.
Far is offline   Reply With Quote
Old   March 5, 2012, 09:40
Christoph
i choose my primary blocking approach
Old   March 5, 2012, 12:06
Far
Sijal
nice work
Old   March 7, 2012, 10:31
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Agreed, nice work... But you never showed your final topology
This is the official topology from my tips and tricks ppt... It is just half of 1 out of 117 slides... You can get it in the ANSYS customer portal.
Of course, this just shows the first step. you would then add the Ogrid thru the volute, etc.
Far, alienplanet, OliverL and 2 others like this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   March 7, 2012, 11:16
Far
Sijal
Then I should say to PYSMN, "Very very nice work"
Could you please share these master tricks on forum or through pm?
Old   March 7, 2012, 13:39
Christoph
no guys, that's not the blocking i used. i ASKED if this is the best blocking in your opinion, not that i was going to use this blocking
my geomtry also included an outer heatshield and a angular stat_rot interface, not just the volute. so it wasn't that easy
you can see my blocking in the attached pics.
Far, PSYMN, ryanzhou and 3 others like this.
Old   March 7, 2012, 13:40
Christoph
I've still have to add the finishing touches (edge params, smoothing etc)
i can't provide blk. and .tin file in general, cause it's property of my company
Far and alienplanet like this.
Old   October 17, 2012, 14:30
Oliver L.
OliverL is on a distinguished road
I wasn´t able to find this "tips and tricks ppt" on the ANSYS customer portal. Has anyone found it yet?
OliverL is offline   Reply With Quote
Old   October 17, 2012, 16:08
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
here is the link https://docs.google.com/file/d/0ByIL...BQT3pQMjQ/edit
anand32 likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   October 17, 2012, 16:55
Oliver L.
Thanks a lot!
Old   October 18, 2012, 08:48
Christoph
Originally Posted by OliverL View Post
Thanks a lot!
as you can see on my statetments, it's not that simple.
especially if you have to regard heatshield geometry etc
tongue is also tough. if your geometry is complex and you're not that experienced in using icem hexa, i would suggest tetra with prism
Old   October 18, 2012, 15:47
PSYMN's Avatar
Simon Pereira
Another good "trick" is to create quad elements in the right pattern...
You can create elements manually under the Edit Mesh tab.
Just lay them out to form the shape you want, including that little Y block region.
Then Extrude them up into Hexa blocks.
Then File => Blocking => Load from Unstructured mesh will turn those into a blocking file.
Then associate that blocking with your actual volute geometry.
Pretty quick way to block a difficult geometry like this.
bluebase and abdalla67 like this.
Old   January 23, 2014, 08:24
Raghav
raghav is on a distinguished road
Hi Simon/ Christoph/ Sijal/ Ali,
Please Check the post :
http://www.cfd-online.com/Forums/ans...ompressor.html
My blocking strategy is not convincing.
Is there any better blocking strategy for this kind of complex Volute?
Can anyone build a topology for this?
Regards,
Raghav
raghav is offline   Reply With Quote
Old   September 7, 2014, 21:59
Fabricio
fabriciotb is on a distinguished road
Send a message via MSN to fabriciotb Send a message via Skype™ to fabriciotb
Dear friends,
I'm trying to follow the steps just discussed but I can't do that. Someone could help me?
Thanks.
fabriciotb is offline   Reply With Quote
Old   September 8, 2014, 15:43
Sebastian Engel
bluebase will become famous soon enough
Hi Fabricio,
before trying something as complex as a volute i suggest you to do the ICEM tutorials.
A first flaw i can see in you screen, there seem to be no edge-to-curve or similar associations. Only automatic edge-to-surface can be seen (the white edges). These Associations are fast and easy, but are not easily shaped. Check out the screenshots of energy382. You might notice many green edges, which means it's an edge-to-curve association. Also, you might not need as many radial splits as you did. It's just more work to put all vertices in place. Compare this again with energy382's.
For a first attempt to reduce the mess in your blocking, create some circumferential curves for every radial split of your volute to be able to put some edge-to-curve associations.
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   September 9, 2014, 03:07
Far
Sijal
Originally Posted by fabriciotb View Post
Dear friends,
Thanks.
see the trick by Simon
Old   September 14, 2014, 21:03
Default Hexa Mesh
  #20
Fabricio
Dear bluebase and Far,
Thanks for all help. I followed your suggestions but I was unsuccessful to create the hexa mesh. The picture shows the problem I have been had.
Could you help me to create this mesh?
Thanks.
[blockMesh] meshing a cylinder Nico A. OpenFOAM Meshing & Mesh Conversion 6 June 19, 2017 15:12
[blockMesh] BlockMesh number internal faces and boundary ynos OpenFOAM Meshing & Mesh Conversion 6 December 13, 2011 06:36
[blockMesh] meshing a cylinder Nico A. OpenFOAM Meshing & Mesh Conversion 0 April 7, 2011 12:09
[blockMesh] Blockmesh error - 2D scramjet ishaninair OpenFOAM Meshing & Mesh Conversion 7 March 18, 2011 01:14
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
