[DesignModeler] Meshing fluid domain through hollow pipes |
February 21, 2012, 11:08 |
John E
Rep Power: 14 |
What tools would you use to define the fluid domain inside pipes if you have a model of the actual physical part? I hear that the FILL-tool is far from powerful (will easily give error messages) and that I should try to pursue other methods. Do any of you have some experience with this?
Cheers. |
February 24, 2012, 21:08 |
Erik
Rep Power: 23 |
Fill is what I would use, and have used, I haven't gotten errors. Have you tried it?
February 25, 2012, 04:17 |
John E
Rep Power: 14 |
Yes, I've tried fill. I most of the sections it complains about troublesome geometry. The entrances to the tube is a bit off-axis (they need to be) so perhaps this twisting is the thing that makes the fill function confused.
Hey, I could send you the geometry if you want to take a look. |
February 25, 2012, 09:14 |
Erik
Rep Power: 23 |
Sure why not, I'll pm my email.
February 26, 2012, 13:30 |
Erik
Rep Power: 23 |
Sent the Geometry back to you. Fill wouldn't work right so I used "enclosure"; and made planes at the faces that cut off the enclosure at the pipe ends, then suppressed the enclosure body outside the pipe.
Sent you back the .adgb file, I think you should be able to open this in design modeler. Let me know if you have any problems with it. |
March 8, 2012, 03:29 |
John E
Rep Power: 14 |
How can you choose to suppress _only_ the part of the enclosure that is outside? Both the outside and inside will be the same (enclosure) body, I take it.
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? | acro | CFX | 15 | September 23, 2016 11:16 |
Constant flow rate through a small area inside the fluid domain. | robingilbert | OpenFOAM | 7 | October 4, 2010 16:19 |
block geometry inside fluid domain | jeff | Main CFD Forum | 18 | April 12, 2004 11:37 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
