[ICEM] how to define periodic for free type face in hexa meshing
Old   February 5, 2012, 02:55
Default how to define periodic for free type face in hexa meshing
Ming Cai
mingersai is on a distinguished road
I set up the periodic under mesh tab=>global mesh setup=>setup periodicity.
For mapped face block, face periodicity will be made by making 4 pairs of periodic vertices,
however, for free typed face, theirs either less or more than 4 vertices, after making all the vertices periodic, the face block is still not periodic.
Are there any way to make two free type surface block into periodic pairs?
Second question is how to make surface mesh periodic
I ran octree periodic is fine, but i can not control the ratio on both surface and volume. and I noticed that one of the periodic surface have to be in line with XY, YZ, or XZ planes. Is that correct?
then I tried to generate the surface mesh for all the surfaces and then use Dulaunay to fill the volume. However, I check the total elements on a pair of periodic surface, it's different.
How to generate periodic surface mesh?
mingersai is offline   Reply With Quote
second order schemes marine OpenFOAM 67 April 11, 2022 19:19
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
