[ICEM] How to generate this kind of mesh?
Like Tree18Likes
Old   October 3, 2012, 14:43
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
A CGrid is really the best kind of grid for a problem like this... It is like having a super thick boundary layer, very efficient and great for Navier Stokes. It is also pretty easy to do (and there is a youtube video with the steps).
The tricky part is the region between the wing tip and the far field wall.
It will likely consist of a rectangular block in the leading edge and a triangular block in the trailing edge.
The rectangular block will have trouble fitting to the curved leading edge of the wing tip. You will either get wide angle elements or need to put an Ogrid block in there, which will still give you bad quality (but better). However, if you sweep it with a paved mesh, you gain alot of freedom. Similarly, the trailing edge block will have a lot of sliver elements as the mapped block is collapsed. There isn't really a good fix for that... I guess you could use a quarter Ogrid, but you will still have pain. A swept block is an easy fix for that also.
Basically, you start with a regular blocking and then change those two blocks to swept at the end...
If you get your hands on R14.5, you can even specify to use the gambit paving algorithm, which is a bit better than the ICEM CFD one for this sort of thing.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   October 3, 2012, 14:55
cfd seeker is on a distinguished road
Confused....are you talking all this for Hexa Blocking or with reference to Multizone?
cfd seeker is offline   Reply With Quote
Old   October 3, 2012, 15:03
PSYMN's Avatar
Simon Pereira
The line between can be blurred...
But I am talking about starting with top down hexa and then converting block types, not bottom up multizone from surface blocking.
Old   October 3, 2012, 15:35
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
cfd seeker,
Look at this threak, http://www.cfd-online.com/Forums/ans...brid-icem.html i sometimes pin the thread that i find useful, may be this one is, look at reponse number 5.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 20, 2012, 13:57
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Originally Posted by BrolY View Post
Blocking -> Edit Block -> Convert Block Type
That should work !
that does not work. i've been trying to convert a mapped block to free hoping this improves the quality of the mesh but icem prints a message that reads "could not convert degenerate hexas to free no block number 217 found". i don't understand this message since the block 217 is there.
cesarcg is offline   Reply With Quote
Old   November 21, 2012, 11:47
diamondx's Avatar
Ghazlani M. Ali
Are you trying to mesh the wing with multizone feature ???
Regards,
Ali
Old   November 21, 2012, 11:56
Cesar
i'm trying that since it seems the only way to improve the quality of the elements in the degenerate hexa block located at the sharp trailing edge of the airfoil section.
regards,
César
Old   November 21, 2012, 12:08
diamondx's Avatar
Ghazlani M. Ali
from my personal experience multizone is very picky when i comes to geometry. before perfoming the build topology, you will need a neat geometry, it is also a new feature in ICEM . it is full of potential but i have always failed to use it with complicated geometries.
After taking a look at your wing, the automatic surface blocks can't generate 2d block in the wingtip. in the other thread i saw that you did a blocking, the attached blk file gave me nothing, would you mind re-sharing it again. could you get good block using the multizone features on you wing ??
Regards,
Ali
Old   November 21, 2012, 12:18
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You must create the Ogrid around the wing + winglet and your topology looks good now. Then you can use the collaspe command to account for the sharp trailing edge. But use the collapse command after creating the O-grid around wing and winglet.
Far is offline   Reply With Quote
Old   November 21, 2012, 12:20
Cesar
please refer to this post where i shared the files.
http://www.cfd-online.com/Forums/ans...ck-method.html
Old   November 21, 2012, 12:25
Cesar
Far,
I tried that but I get triangular elements where I collapsed the blocks. The quality analysis tells me that I have inverted blocks near this region.
Regards.
Old   February 16, 2017, 08:32
waiter120 is on a distinguished road
Finally !
https://www.youtube.com/watch?v=HmEz...index=11&t=19s
https://www.youtube.com/watch?v=RHqr...XKRt9&index=10
waiter120 is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 08:08
generate different mesh in CFX_MESH Eric CFX 0 June 23, 2006 10:09
