[ANSYS Meshing] Meshing strategy for External Flows
Old   January 24, 2012, 15:27
Exclamation Meshing strategy for External Flows
Ali
Hybrid is on a distinguished road
I have recently shifted to Ansys WB.
I am working on a wing body configuration. I imported an external cad file (Parasolid/Catia) in Ansys DM, perform some operations(Boolean+Body operations, etc.). I enclosed my full-body (360 deg) in a sphere user-defined Enclosure. Everything is quite good at this stage. In DM model view there are 2 parts (one is my body as solid and second is sphere enclosure as fluid.
After that I link this geometry to Ansys Meshing, after taking some time, I see the geometry in Meshing environment. Ansys meshing defined contact regions. I started automatic meshing.
After the process ends, there are a mesh inside my body (solid) as well. there are overlapping surfaces too.
Is it wrong? If so, where?
Whether I have to take both parts in Ansys meshing or suppress body and take Enclosure only to the Ansys Meshing from DesignModeler.
I have also tried it in ICEM, after spending 15 days on same geom, I am tired now.
Need help.
A quick reply will be highly appreciated.
Hybrid is offline   Reply With Quote
3d meshing strategy for propeller in gambit Harikrishna FLUENT 3 January 12, 2012 07:38
Meshing strategy for a tapered tube Dave FLUENT 0 January 4, 2006 14:20
meshing strategy for tight fit. jemteo CFX 4 August 10, 2004 03:30
pro-am meshing of external flows Joel Davison Siemens 1 January 16, 2002 06:37
block meshing strategy J Reed Siemens 0 March 7, 2000 12:41
