[ICEM] Domain definition in 2D model
Old   January 24, 2012, 06:41
Default Domain definition in 2D model
Nic Patkwoski
nprace is on a distinguished road
Hello all,
I am trying to generate a 2D mesh in ICEM to simulate in CFX. The problem is a rectangular channel through which air flows with a porous domain placed in it. The porous domain is a plate which does not occupy the entire volume of the channel. My 2D model will then represent a cross section of the channel (cir. 0.3 x 0.075m) with a smaller rectangle placed in the middle (0.01 x 0.15m).
I am using ICEM to generate the mesh with blocking. I apply the blocks and associated edges as per the 2D tutorial and generate a pre-mesh which I then extrude after converting to unstructured mesh. I have managed to define parts for the inlet and outlet of the body as well as for the symmetry surfaces.
However, I cannot define two regions where the two different domains are to be placed and thus cannot define this in CFD-PRE.
As I understand, this should be done before the mesh is generated with bodies or is that only valid with volume elements in a 3D model?
If there are further tutorials to this effect I would be thankful for your suggestions.
Thanks and regards.
Nic
nprace is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Parameter definition for Spalart-Almaras turbulent model teopetre FLUENT 0 December 19, 2011 16:31
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
CFX domain error message about multiphase model Jane CFX 0 March 5, 2009 11:30
