[ANSYS Meshing] Periodic issues in cutcell meshing
Old   January 20, 2012, 04:05
Default Periodic issues in cutcell meshing
jsm
JSM
jsm is on a distinguished road
Dear All,
I tried to mesh the model that has rotational periodicity using cutcell method. But mesh in periodic faces are not similar. Is it possible to use cutcell meshing for periodic models?
With regards,
JSM
jsm is offline   Reply With Quote
Old   January 31, 2012, 07:42
jsm
JSM
At last I found that periodic meshing is not possible with cutcell meshing.
Is there is any chance it will be available in next release?
This is much useful meshing method but I could not use it in my models because of this limitation.
With regards,
JSM
Old   March 6, 2012, 12:03
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
But you can create the GGI periodic in Fluent . No need to set it in ICEM
Far is offline   Reply With Quote
Old   March 7, 2012, 22:56
jsm
JSM
Hi Far,
Thanks for your information. I also thinking of using this option in Fluent. But due to GGI interface also, there will be some accuracy loss.
What do you think about this? Did you used this option before and validated for accuracy and result variation?
By the way, I am trying to use Ansys meshing (AMP) for meshing not ICEM CFD.
With regards,
JSM
Old   March 7, 2012, 23:22
Far
Sijal
CFX has been offering this option for long time and it is very much successful specially in rotating machinery.
Loss of accuracy is not noticeable as compared to other losses such as turbulence model, flow scheme, convergence error and interface error (e.g. mixing plane in rotor-stater interaction). I tried in CFX as well in Fluent and I am fully satisfied with results.
Yes, you are correct as this option is only available in AM not in ICEM.
Old   March 8, 2012, 10:53
jsm
JSM
Hi Far,
I am using only Fluent for simulations. I never used interface in periodic boundary condition as I thought this will reduce the accuracy of results.
I think that I should try once with GGI interface in Fluent. And let's hope periodicity option for cut-cell meshing will be available in next release (Ansys 14.5).
Once again thanks for your comments and response.
With regards,
JSM
Old   March 8, 2012, 11:51
Far
Sijal
According to my observation (it is fact also) , after acquisition of Fluent (later) and CFX (earlier) by ANSYS, ANSYS is making both codes stronger by combining their strong points and replacing their weak points.
When I referred to CFX's GGI, actually I was trying to highlight that Fluent is now also equipped with same technology.
Old   March 8, 2012, 22:00
jsm
JSM
Hi Far,
Ok. I got your points.
I will perform one simulation with GGI interface and let you know if I face any issues.
Thank you
With regards,
JSM
[ICEM] Global Element Seed Size? Tetra meshing issues info_bahaider ANSYS Meshing & Geometry 0 November 28, 2011 09:12
Meshing issues with StarCCM+ Ganephtes STAR-CCM+ 2 May 12, 2011 04:51
Ansys meshing of two-phase periodic domain kcsmith ANSYS Meshing & Geometry 11 March 9, 2011 22:08
[GAMBIT] Meshing with periodic BC Daggemann ANSYS Meshing & Geometry 1 April 7, 2009 08:16
problem in meshing a periodic boundary dumas FLUENT 4 March 8, 2006 11:54
