[ANSYS Meshing] help me for modal analysis of steel structure
Old   December 5, 2011, 07:43
Default help me for modal analysis of steel structure
m farouk
Eng medo is on a distinguished road
i want to make modal analysis of steel structure
Problem Description
Section properties:
Columns:
Box section 4 x 4 cm, thickness 2 mm
Beams:
Box section 4 x 2 cm, thickness 1.5 mm
Material properties:
Weight per unit volume γ = 7.849 t/m3
Poisson’s ratio σ = 0.3
Modulus of elasticity E = 2x107 t/m2
Weight of steel plates:
140 kg at each floor
Their mass is concentrated at columns
Notes:
• All column to beam connections are completely rigid
• Columns are fixed at base.
i want to ask about
1- element type
2- meshing options
3- how to apply loads due to weight
4-how to get the damping with natural frequencies and mode shapes
5- 'All column to beam connections are completely rigid; what is the mean of this statement in the options of analysis
Eng medo is offline   Reply With Quote
Modelling the cross aisle direction of a steel selective rack for model analysis m8rix ANSYS 0 September 20, 2011 11:28
3D analysis of Ahmed body Irshad22 FLUENT 0 December 17, 2009 05:33
Analysis for bake-out of a structure anna_67 CFX 2 July 8, 2009 19:32
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 18:46
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 13:58
