December 1, 2011, 06:58 |
Creating Fluid Volume
Will
Rep Power: 15 |
I am having trouble creating a fluid volume around an object in design modeller. In the past, for more simple objects, I have drawn a primitive box and changed its properties to fluid. My current model has primitive parts in it already, and this results in them simply merging with the box when I draw it. Is there an alternative way of creating the fluid volume, or keeping the other primitive objects separate? I have tried Tools>Enclosure, but only get an error message. (Error: Boolean operation failed) Thanks for any help! Will |
December 13, 2011, 12:19 |
Kailash
Rep Power: 15 |
freeze the primitive objects before creating the outer box.
December 16, 2011, 06:45 |
for fluid domain
u can use enclosure option in design modeler for creating fluid around body
February 23, 2012, 09:34 |
arjun
Rep Power: 15 |
how to create hole in the enclosure. ?
i have solid body in the enclosure, and i want to impinge the jet on that body through nozzle, that's why i need to create the hole on the enclosure. please help. |
February 24, 2012, 01:15 |
Ali
Rep Power: 16 |
you must use user-defined enclosure.
Make a far-field body (as solid), put a hole in it in modelling. then using enclosure's User-Defined option, select the new solid body that you just created. Then Generate.... Before doing these steps, you must freeze your original model. Hope you will be able to see your required geometry. Regards Ali |
There is no fluid volume in the project | Giron | FloEFD, FloWorks & FloTHERM | 5 | December 30, 2022 09:58 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
[Gmsh] Creating a fluid domain | alexandrepereira | OpenFOAM Meshing & Mesh Conversion | 1 | May 11, 2008 08:47 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 02:40 |
