[ICEM] How to create hard points on surface for 2d meshing?
Old   November 27, 2011, 01:47
Default How to create hard points on surface for 2d meshing?
Alex
ale-kc is on a distinguished road
Hello, my task is very simple: It is necessary to create mesh of several connected (through the fasteners) parts .
Parts will be modelled by 2d(shell) mesh and fastener modelled by 1d elemten (node to node connection).
So, I need nodes in parts in appropriate position for fastener connection.
In Patran and FEMAP it can be done by hard points, but I'd like to do it with ICEM.
Please can anyone help me with my task?
ale-kc is offline   Reply With Quote
Old   November 28, 2011, 15:46
Default settings => product set to "FEA"
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sure, if you have your settings => product set to "FEA", the mesh tab will have options for bolt spiders and other connectors (spot welds, seam welds, etc.)
You can also just create line elements between notes and assign ridged (or weighted rigid or beam or spring, etc.) properties to them.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   November 28, 2011, 16:45
Alex
Simon, thank you for your answer.
But I can't find such function which allow me automatically place nodes in appropriate positions (pre defined before, for example using points on surface).
May be ICEM can't do this?
Old   November 28, 2011, 20:58
PSYMN's Avatar
Simon Pereira
If you put a point on a surface (you can create these many different ways including uv of the surface or xyz in space), the mesher will automatically create a node at that location... The connectors tools will let you select those points or seam curves or what ever for connectors, etc.
Old   November 28, 2011, 22:01
Alex
Thank you! It works.
how to create angular points in fluent(angular-rake) srikanth-aero FLUENT 1 February 21, 2011 13:25
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
