[GAMBIT] Ask about how to set up geometry and mesh for moving mesh case |
December 20, 2011, 03:08 |
#21 |
Maxime Perelli
Rep Power: 41 |
yes enable the dynamic mesh, else you cannot access to dynamic mesh zone.
But don't change anything, since your mesh will not be updated (no layering, no smoothing and no remeshing)
In memory of my friend Hervé: CFD engineer & freerider |
December 20, 2011, 03:13 |
#22 |
noken
Rep Power: 14 |
thanks boss, really appreciate it. btw come visit my country indonesia
December 21, 2011, 03:10 |
#23 |
noken
Rep Power: 14 |
hi max i have problem again..
i have two interface in my geometry in fluent i tried to connect them using coupled but the contour of velocity was so weird check this out that is contour for initial solution..the wall is not rotating..but whay the fluid didnt pass the valve?? |
December 21, 2011, 03:13 |
#24 |
Maxime Perelli
Rep Power: 41 |
yes you have problem at interfaces
Check if they are well defined. I am in vacation untill January the 4th.
December 21, 2011, 03:19 |
#25 |
noken
Rep Power: 14 |
but why??i think it had been defined well.. i have two surface not connected, i give that surface interface rotor and stator after that i use FLUENT to defined the interface type as coupled...
December 21, 2011, 03:24 |
#26 |
Maxime Perelli
Rep Power: 41 |
no you need to define the edges as interface.
Between rotor and stator, only edges are common
December 21, 2011, 03:26 |
#27 |
noken
Rep Power: 14 |
sorry i was wrong..i mean the edge of both stator and rotor
December 21, 2011, 03:28 |
#28 |
Maxime Perelli
Rep Power: 41 |
no you mean one interface for the stator edges, and another interface for the rotor edges.
In Fluent select both interfaces to define the grid interfaces
December 21, 2011, 03:30 |
#29 |
noken
Rep Power: 14 |
i've done that, and for the interface type i use coupled type
January 2, 2012, 21:13 |
#30 |
noken
Rep Power: 14 |
hi max..me again hope you not bored with me
i'm facing a problem..yes again... in my dynamic analysis using moving mesh, i'm facing the negative cell problem.. can you analysis what was wrong in my simulation, why did this comes up, here is what error like to be |
January 4, 2012, 01:47 |
#31 |
Maxime Perelli
Rep Power: 41 |
something is wrong since you are not suppose to change your mesh.
Check where are the negative cells
February 3, 2012, 06:33 |
#32 |
Efthymios Efthymiou
Rep Power: 14 |
Hi my friend, I am currently working on a similar project. I have to design a check valve. Is that working for you? Shall I follow the steps of your discussion??
September 8, 2012, 11:26 |
#33 |
Satish Gupta
Rep Power: 14 |
I am also plannin on using Sliding mesh to rotate a square Cylinder 2D....can ny1 help in defining interfaces.....I am not able to understand how we have two interfaces from d same circle...Do I have 2 make two circles nd define dem as interfaces
September 10, 2012, 00:55 |
#34 |
Maxime Perelli
Rep Power: 41 |
imagine a surface with a hole (disk) > you are agree that in this surface you have a circle.
imagine now a disk not located on the surface mentionned earlier, but anywhere > you are agree that a circle (edge) is attached to this disk You have then 2 circles. Now move your disk in such way, that it will cover the hollow from first surface. Finally you have defined a stator (first surface), and the rotor (disk) which are disconnected. And you also have 2 superposed interfaces (one belongs to stator surface and the other belongs to the rotort (disk)) Here the interfaces are the circles (edges) I Hope I was clear
September 10, 2012, 08:01 |
#35 |
Satish Gupta
Rep Power: 14 |
thanks max....How do I couple the two interfaces
1.coupled 2.periodic or 3.periodic wall boundary. I found these 3 options in fluent |
September 10, 2012, 08:03 |
#36 |
Maxime Perelli
Rep Power: 41 |
don't remember anymore, but coupled should be ok
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
