[ANSYS Meshing] dealing with a complex CFD Geometry
Old   November 14, 2011, 04:47
Default dealing with a complex CFD Geometry
Maximilian Hauser
mountaineer is on a distinguished road
Hi @all,
I want to mesh a complex geometry with Ansys Mechanical for a CFD simulation. The geometry has been prepared with Pro/E and imported to Ansys WB 13 and has about 38 parts. In the DesignModeler I have created the fluid geometry with a boolean operation. I decided to use cutCell Meshing with inflation layers.
cutCell meshing without setting inflation layers works, but when I add inflation layers, the mesh generation fails. Now I want set inflation layers surface by surface to find out the problem.
How can I select the surfaces for named selections in a comfortable way? I think, the best thing would be a automatic generation of the named selections oriented by parts. e. g. I have a part and want to create named selections for all surfaces of this part. Is this possible with Ansys?
thanks!
with best regards
Mountaineer
mountaineer is offline   Reply With Quote
Programming a CFD code using complex variables New coding Main CFD Forum 1 July 3, 2008 22:32
EXTRUDE option in ICEM CFD Geometry Mohammad Faridul Alam CFX 4 October 25, 2007 18:47
how to deal with complex geometry using ICEM? prayskyer CFX 3 June 20, 2006 08:33
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 0 August 1, 2000 11:07
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 13:58
