October 27, 2011, 06:20 |
Generating a Uniform mesh with ICEM
Rep Power: 18 |
To generate a uniform mesh for the Fluid volume in ANSYS workbench I was resorting to body sizing and global mesh settings but in the case of ICEM CFD I don't see any thing like body sizing so would it be just fine to simply go with the global settings over there to get a uniform mesh in ICEM CFD.
Best regards, Santhosh. |
October 27, 2011, 06:31 |
AB
Rep Power: 22 |
Do you want Hexa or Tetra mesh?
For Tetra mesh, you have to create a body (Geometry -> Create Body). For Hexa mesh, ICEM creates a new part (by default SOLID). Then, go to Mesh -> Part Mesh Setup and set the size for each part. |
October 27, 2011, 08:10 |
Rep Power: 18 |
Thanks for the reply Boles , I meant about the Tetra mesh
October 27, 2011, 09:13 |
Mesh Density
Simon Pereira
Rep Power: 47 |
I think Santhosh is talking about setting sizes on a part... More specifically, mesh density within the volume of a part. He probably wants to set this size smaller then is overall global max size.
Under the Mesh tab, you can set sizes by part, but that applies to the surface and curve entities of that part. ICEM CFD doesn't really have the same concept as a "solid", so if you want to set the max size for a body (the full volume within a part), you really need to create a density region. You can create this around the part, but it will start as a box from min xyz to max XYZ. You can modify the corners to fit better, but some shapes work best with a number of smaller density regions overlapped. Get started on that and I can answer more specific operational questions later.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
October 27, 2011, 11:07 |
Rep Power: 18 |
Many thanks for the reply Simon and yes I was looking for the volumetric size so ill start with the creation of density regions
Free jet simulation | msarkar | OpenFOAM Running, Solving & CFD | 39 | May 11, 2021 14:21 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 18:08 |
turbulent jet simulation | antonio_ing | OpenFOAM Running, Solving & CFD | 5 | September 16, 2010 03:31 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 07:28 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
