[ICEM] Mesh Decoupled Mesh Movement in ICEM
Old   October 26, 2011, 17:06
Default Mesh Decoupled Mesh Movement in ICEM
Julian Krick
Julian K. is on a distinguished road
Hi!
I would like to simulate a case similar to the scenario 'Rigid Body Simulation with Decoupled Mesh Movement' (chp. 32.6 of CFX-Tutorial Guide), but I don't know how to prepare my mesh properly. Especially, I don't know how to tell ICEM, that there are two independet meshes for the region around the body and the farfield.
So my domain should look like in the attached PDF-file. The fine mesh should move with the cirlce and the coarse mesh is supposed to deform.
I also attached a geometry file for ICEM, which I use for testing purposes. There you see a square cylinder in the middle and a regrion around it, which should move with the cylinder in the simulation. Around that is the farfield mesh, which is supposed to deform.
So, do you know how to set up my mesh in order to be able to tell CFX, that the inner mesh is attached to the circle?
I imported the mesh of the CFX-Tutorial and I shaw, that there are 2 "Principal 3D Regions". How did they do that?
Cheers,
Julian
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
cfx, decoupled mesh motion, icem, mesh deformation
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
ICEM Edit Mesh blackbody ANSYS Meshing & Geometry 3 March 8, 2010 03:49
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 07:07
How to corse mesh in icem cfd? Priety CFX 2 October 2, 2006 04:57
