[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream
Old   October 26, 2011, 14:49
Default GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream
rocketman1151 is on a distinguished road
Hello All:
I am new to GAMBIT and have a project I am working on that involves a spray bar. It consists of a pipe with fluid entering one end and exiting out the other. Along the pipe are multiple sets of holes so that part of the fluid sprays out through the holes as well as out the end of the pipe. I am to use circular o-grid meshing and the question is two-fold: First, how to model the holes in the side of the pipe. Secondly, how to handle the intersection of the main o-grid mesh through the pipe with circular o-grid meshes from the holes (if that is the right way to do it). If I don't need to use an o-grid mesh for the holes, what is the best way to mesh them? Thank your for the help!
Rocketman1151
rocketman1151 is offline   Reply With Quote
Old   October 27, 2011, 02:48
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you have always many ways for meshing geometry.
Can you post a picture of your model (or a sketch).
The quickest way to mesh such stuff is using tetra-hexcore with size function (and perhaps Boundary Layer).
But the first thing to ask you is: do I need hexa mesh?
Hexa mesh isn't so trivial and overall not automatic (volume decomposition)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 28, 2011, 11:10
Default basic sketch of spraybar
OK, if I attached it correctly, you should be able to open the basic spraybar sketch. I will model only one tube (the sketch refers to multiple design) and the segment of interest in the sketch is the vertically oriented one as the other segment is the inlet line. I will model two sets of holes near the top of the spraybar. The holes will be drilled through the tube, so each set will comprise two holed at 180 degrees apart circumferentially. The sets will be located about one-two inches apart and the first one will be located about one inch from the top of the pipe, which will be open (i.e. not restricted). I am supposed to use o-grids for the flow through the pipe as well as for the intersecting holes located on the sides of the pipe. It is how to best model the holes and how to handle the intersecting o-grid meshes. Thanks for the help!
[IMG]file:///C:/Users/MCQUAD%7E1/AppData/Local/Temp/moz-screenshot-16.png[/IMG]
[IMG]file:///C:/Users/MCQUAD%7E1/AppData/Local/Temp/moz-screenshot-15.png[/IMG]
Old   October 28, 2011, 11:16
-mAx-'s Avatar
Maxime Perelli
it is already built in Gambit?
Old   October 30, 2011, 22:04
No, I am just at the beginning of learning how to use Gambit/Fluent in preparation for modeling the spraybar. I was hoping to get some pointers before moving out and setting it up.
Old   November 2, 2011, 02:02
-mAx-'s Avatar
Maxime Perelli
Then build your geometry first. Then mesh it.
For building your model, you just need to create cylinders, and move them at their right places (translate-rotate).
Finally you may unite all the cylinders together.
Old   November 26, 2011, 18:39
OK, what I did was create the pipe using quarter circles and then joining them together to make the two ends and then placing lines between them to form the wireframe. I then made the holes using points on the lines and creating two sets of two-arcs on opposite sides of the pipe wireframe and then making faces from them. The idea is then to subtract the faces from the pipe volume so that they form the holes on opposite sides of the pipe. I then am supposed to use an o-grid through the pipe and square grid intersecting the o-grid at the "hole" Does that make sense? Any thoughts on how to handle the intersection of the o-grid and square grid? Thanks.
Old   November 30, 2011, 03:39
-mAx-'s Avatar
Maxime Perelli
you cannot substract a surface from a volume.
you can substract a volume from another volume, or a face from another face.
I think you wanted to say "split"
gambit mesh, gambit-pipe flow
[GAMBIT] Meshing a pipe vedravi ANSYS Meshing & Geometry 1 March 25, 2010 14:19
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 02:09
[GAMBIT] Surface Meshing Issues in Gambit Forrest ANSYS Meshing & Geometry 4 March 27, 2009 15:22
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 06:04
meshing difficulties in gambit jyothish FLUENT 6 June 7, 2004 05:13
