October 24, 2011, 11:10 |
Complex 3D Hexa Meshing
Andre Pereira
Rep Power: 14 |
Dear All,
I've been trying to develop a fairly automated way of producing a Hex mesh for a quite complex geometry. I'm using Ansys ICEM CFD 13.0 and would like to have a scripted way of filling the space in between Quad surfaces. I'm starting with a couple of STL files, corresponding to the outer and inner surface of a mouse tibia. The geometry is non-convex and with lots of problematic regions (Figure 1 and 2). The inside surface is depicted in Figure 3. I would like to ask you for advice on the way to approach this problem. I managed to create surface Quad meshes, by using the Build Topology tools and then create a All Quad surface mesh with Shrinkwrap. However, some hole appear in some regions (Figure 4). Hope you can help me in approaching this problem. Thank you for your attention so far. Andre |
[ICEM] Hexa meshing of impeller and diffuser assembly | Nitin Dewangan | ANSYS Meshing & Geometry | 14 | September 13, 2016 09:41 |
[ICEM] Hexa dominant meshing | Pat84 | ANSYS Meshing & Geometry | 19 | December 2, 2015 17:20 |
Wind tunnel hexa meshing in ICEM CFD 12.1 | matheusguzella | ANSYS Meshing & Geometry | 1 | March 14, 2011 16:14 |
Hexa Block meshes in ANSYS Meshing? | siw | ANSYS Meshing & Geometry | 3 | July 31, 2009 10:40 |
Hexa meshing or Tetra meshing??? | NITIN DEWANGAN | CFX | 5 | August 5, 2008 09:59 |
