[ICEM] Generating Mesh for Decoupled Mesh Motion with ICEM
Old   October 18, 2011, 16:54
Default Generating Mesh for Decoupled Mesh Motion with ICEM
Julian Krick
Julian K. is on a distinguished road
Hi!
I would like to simulate a 2D flow over an oscillating cylinder using CFX 13.0. The mesh will be created with ICEM 13.0 and should be composed as follows (see figure in attachment):
The cylinder is situated in a subdomain with a fine grid. This subdomain should be connected to the cylinder movement. Thus, the subdomain follows the movement of the cylinder, causing only the outer mesh to deform (similar case as in the tutorial in chapter 32.6 'Modeling a Buoy using the CFX Rigid Body Solver' of the ANSYS CFX Tutorials).
My questions are:
How to create the subdomain, so that CFX recorgnizes them?
How to define the interfaces in ICEM?
How would you create this mesh?
Cheers,
Julian
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
cylinder, decoupled mesh motion, icem, oscillation, twodimensional
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 09:16
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 13:16
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
