[ANSYS Meshing] Problem with Icem Script
Old   October 18, 2011, 13:10
Default Problem with Icem Script
Krishan Parmar
Krish is on a distinguished road
Hi everyone,
I am having a problem with an icem script that I am trying to use.
The script creates and airfoil and places an object (at a given point) on the airfoil surface.
So basically, as my object move along the airfoil, Block 1 should increase in the number of nodes and block 2 should decrease in number of nodes. All this should occur keeping the edge spacing fixed.
The problem I have is that script does not pickup the correct edge spacing provided by the script. Below is a sample line:
ic_hex_set_mesh 42 35 n 105 h1rel 0.0004 h2rel 0.0 r1 2 r2 2 lmax 0 geo1 copy_to_parallel unlocked.
This should provide a node spacing (using geo1 so spacing 1) of 0.0004 but in reality it become something around 0.00029 range!!!
Any suggestions are welcome
Thanks
Krish
Krish is offline   Reply With Quote
ICEM keyboard problem in linux gravis ANSYS Meshing & Geometry 4 February 28, 2020 10:23
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 14:14
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
Problem exporting big meshes from ICEM to Fire Emil CFX 0 October 10, 2008 14:06
