#21 |
Sebastian Engel
Rep Power: 21 ![]() |
Hi sertac,
to every new user i would suggest you to do some of the tutorials which come with ICEM. About your problem: there are a few methods to get the cross section of your 3d geometry. For example: Import your 3d geometry. Create a planar surface covering your foil in a plane where your need a cross section. Then intersect the surfaces of the airfoil with your planar surface. That way you get curves of a cross section. Delete everything unnecessary and start building your numerical domain. |
#22 |
mostafa yussof
Rep Power: 0 ![]() |
Hi,everybody
How can i do compressor blade meshing in 2D by ICEM ? |
meshing of turbine blade | jayaero | ANSYS Meshing & Geometry | 25 | July 25, 2014 09:52 |
meshing turbine blade | ponnusamy | Main CFD Forum | 6 | March 18, 2011 01:55 |
Wind turbine blade meshing | caohan | FLUENT | 12 | April 22, 2010 10:49 |
Setting up gas turbine blade geometry for meshing | sherifkadry | Main CFD Forum | 0 | June 1, 2009 16:28 |
Meshing pitched blade turbine | Racheal | FLUENT | 0 | July 12, 2005 13:25 |
