ICEM 13_Coordinates change after reading geometry from Solidworks; any ideas?
Old   August 24, 2011, 14:23
Default ICEM 13_Coordinates change after reading geometry from Solidworks; any ideas?
Catthan is on a distinguished road
Dear all,
I am trying to model the gas circuit of a Wankel rotor in Fluent and I'm facing a problem which originates- I think- when I import the soliworks file to ICEM 13 (through WB readers etc)
So what happens is that min and max (x, y) in solidworks are different from those in ICEM and then fluent. It's not just an offset which I can translate back to where I want because the offset in the positive x or y axis is different from that in the negative axes
Example,
Solidworks: min (-0.095, -0.073) max (0.095, 0.073)
ICEM/ Fluen: min (-0.0953278, -0.072578) max (0.0951, 0.074656)
I used random numbers but close
It's important 'cause I have a CG motion UDF with the eccentricity etc and I need to get the coordinates spot on,,
I would appreciate any ideas
Best,
Thanos
Catthan is offline   Reply With Quote
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
[ICEM] Import geometry from solidworks holyo ANSYS Meshing & Geometry 11 April 16, 2014 12:47
File import from Solidworks to ICEM Dreamdancer ANSYS 0 June 6, 2010 17:48
ICEM --- question about repair geometry zhaohui ANSYS Meshing & Geometry 1 April 21, 2010 19:54
Input Geometry from Ideas to Gambit Knick FLUENT 2 December 11, 2002 04:59
