August 24, 2011, 06:11 |
[ICEM] minor internal error
Rep Power: 17 |
HI Icem-Users,
I am meshing a quite simple cace in Icem but I get this pacifying error message: Code:
A minor internal error has occurred. You may continue to work but if problems arise they may be related to this error. Try using the check/fix function to fix the problem The following message was designed to aid developers fix the problem: error projecting edge 73 to 26 Thanks |
August 24, 2011, 06:22 |
Rep Power: 17 |
solved the problem by associating some edges to curves (not all). Donīt know why sometimes I get this message and sometimes not.
August 24, 2011, 08:30 |
AB
Rep Power: 22 |
Don't pay attention to those messages.
It doesn't mean your mesh is not correct. |
September 13, 2011, 06:13 |
Rep Power: 17 |
Ok I wont. thanks for the reply
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
