symmetry plane error due to a split-block
Old   August 2, 2011, 10:59
Default symmetry plane error due to a split-block
Nick
Nick R is on a distinguished road
Hi all,
I intend to simulate flow over a 3d wing in a c-grid topology. I want to set the side planes (the parrallel ones) as symmetry but once I run cfx it terminates with the error that says one of my symmetry boundaries is not a strict plane.
So I think there might be some nodes that are not correctly positioned. But in ICEM everything looks right and I've checked every nook and cranny for a node that might not be on that plane.
I noticed that this error happens only when I apply a split block to create a boundary layer region (like the tutorial on youtube). As far as I know the associations look fine.
Is there a way to identify the nodes that are problamatic. I used check mesh but that looks fine too.
Any other suggestions are appreciated.
Nick
Nick R is offline   Reply With Quote
Old   August 2, 2011, 23:54
Nick
For anyone interested I solved the problem by using ICEM's move nodes command and specified the symmetry coordinates where I needed my mesh nodes to be then selected the two sides planes.
Old   August 3, 2011, 12:42
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Good. I guess your geometry was a little off plane? ICEM CFD didn't mind, but your solver did. Your solution (just set the location for the symmetry nodes), is the easiest fix. Correcting the geometry would be another approach, but it is often more hassle and not really necessary.
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   August 3, 2011, 23:00
Nick
Thanks Simon. Is there a way to identify those nodes?
Old   August 4, 2011, 18:56
PSYMN's Avatar
Simon Pereira
We had a request for that a while back... Sort of like the periodicity check, but rather a symmetry plane check... But I never managed to get it in.
How can I split a region with plane? JackTheLad STAR-CCM+ 4 March 26, 2011 20:29
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 08:09
ICEM and symmetry plane Roland CFX 3 September 13, 2006 09:38
Symmetry plane and force calculation Roland CFX 7 May 31, 2006 14:34
