June 26, 2011, 19:16 |
2d meshing in ansys meshing
I am trying to import a 2d geometry into Ansys meshing. but there always seems to be some sort of error. I've switched the model type from 3d to 2d in workbench but this is of no use. What kind of 2d files does ansys meshing support? am i even allowed to mesh in 2d in ansys meshing in the first place? ralph |
June 27, 2011, 17:36 |
Anybody? Surely most of you have encountered this before.
June 28, 2011, 14:44 |
Simon Pereira
Rep Power: 47 |
yes, you can mesh 2D geometry in ANSYS Meshing...
Is you geometry in the XY plane (Z = 0)? how did you import the geometry?
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
June 29, 2011, 00:06 |
Hi Simon,
I imported it directly from Solidworks. Solidworks has this addin for ANSYS 13. I can click on it and it will bring the drawing to workbench designmodeller geometry automatically. I was able to import a 3d part drawing from Solidworks but when it comes to 2d, the attachment always gives an error. My geometry is in the XY plane and yes Z=0. Do you have any suggestions? Regards Ralph |
June 29, 2011, 13:07 |
Checked with Development...
Simon Pereira
Rep Power: 47 |
I just checked with development... They are not aware of any issues with 2D from Solidworks. They have regression tests in place and those are all fine.
Are you talking about a 2D model or just a sketch? Is it possible that you have some variance from the Z=0 plane?
October 23, 2012, 23:53 |
matt
Rep Power: 14 |
i have this problem as well, can anyone shed some light on what sort of model can be imported from solidworks for 2D analysis in ansys?
I tried a simple extrued airfoil and it gave errors when switching from 3d to 2d. |
October 31, 2012, 12:21 |
Umut Can
Rep Power: 14 |
are you trying to insert only a sketch if you are doing this, create a surface inside the sketch then try it again.
November 1, 2012, 18:32 |
matt
Rep Power: 14 |
November 1, 2012, 19:56 |
#9 |
Umut Can
Rep Power: 14 |
I don't think you can do that.
If there is anyway, i dont know it, i was thinking that you are already inputting 2-d geometry and DM did not response . I am sorry about misunderstanding... |
November 1, 2012, 20:53 |
#10 | |
matt
Rep Power: 14 |
in what format does it like? |
November 1, 2012, 21:42 |
#11 |
Ovi
Rep Power: 14 |
I remember in the past I was using the import features from solidworks with the plug-in features mentioned and also via various file formats such as IGES or Parasolid.
In order to avoid any errors with geometry and meshing I have decided to move to DesignModeller for most of my simple geometries. It saves so much time especially when undertaking a iterative design or optimisation study. Unless the geometry is complicated or represents some assembly which is used elsewhere, by members of a larger team for example, I have found it much better to just use DesignModeller to produce all the CFD geometry. Just my $0.02. |
How To save a created mesh file in Ansys Meshing | ashtonJ | CFX | 4 | January 7, 2012 23:04 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 21:03 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
[ANSYS Meshing] Ansys meshing with extended meshing | jsm | ANSYS Meshing & Geometry | 6 | January 10, 2011 13:09 |
Hexa Block meshes in ANSYS Meshing? | siw | ANSYS Meshing & Geometry | 3 | July 31, 2009 11:40 |
