June 22, 2011, 07:14 |
cubes on block edges
Max
Rep Power: 15 |
PROBLEM SOLVED
---------------------- Hi, I have a distorted mesh which is caused by cubes on the block edges shown in the picture below. I assume that these cubes are relics of a split block that I re-merged. I have tried a lot to get rid of the cubes but nothing worked. Can anybody tell me what exactly they represent and how to delete them? Thanks! Some more info: - they seem to be part of the edges - if i disable edges in the display tree, they disappear - the lines between the cubes are separate edges although those edges are only separated by the cubes, not by vertices Last edited by murx; June 22, 2011 at 07:34. |
June 22, 2011, 07:33 |
Max
Rep Power: 15 |
Figured it out:
Edit Edge --> Unsplit Edge |
February 21, 2021, 21:01 |
Domoina
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Delete block edges in ICEM CFD | YK | CFX | 1 | June 22, 2008 14:30 |
