[ICEM] Angle of Attack
Old   June 21, 2011, 14:20
Cool Angle of Attack
Karthik
wolvi_ak is on a distinguished road
Hi Friends,
I am analyzing one NACA 662(2)15 wing with 1.5m span and 0.4m chord, i need to change the AOA of the wing to 2.5 deg and find the Drag force. wat can be done to change it.
Also i need some clarifications in the default unit that is taken by ICEM CFD since i deal with meters its confusing me while creating the domain.
Then also, In CFX, the function calculator which gives the forces along x and y direction are drag and lift respectively right ? Pls clarify
wolvi_ak is offline   Reply With Quote
Old   June 22, 2011, 09:31
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ICEM CFD is essentially unitless.
If your model was in meters, it is in meters in ICEM CFD...
If your model was in cubits, it is in cubits in ICEM CFD.
Usually, I check the length of my model in ICEM CFD (using the measuring tape in the top left corner), to figure out the scale. If I don't like it, I go into the Geometry => Transform options and Scale the model.
Unitlless has been pretty good for ICEM CFD all these years, but I think for 14.0, we may add some unit concept to ICEM CFD that would at least keep track of this for you (tell you what the units currently are) and make scaling as easy as selecting the unit system you prefer. It wouldn't change any other behavior though.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   June 22, 2011, 15:49
mjgraf is on a distinguished road
it would be useful to know the units selected for the imported geometry (opening a model from years ago), but in general we keep track of this ourselves or have a few control points in the geometry. And I agree, if it's not broke, don't "fix it".
mjgraf is offline   Reply With Quote
Old   June 25, 2011, 13:10
Karthik
Thanks Guys,
But i have drawn my model using ICEM CFD itself,, so here is the thing, i get absurd results wen i analyse a wing of span 1.5metres, 0.4 chord and AOA of 2.5 deg.
I get a lift force from function calculator in CFX POST as 960 N and drag as 120 N.
Old   June 28, 2011, 14:52
PSYMN's Avatar
Simon Pereira
So you have decided your model is in meters, just make sure that your boundary conditions (velocity, etc.) are in the correct units also... (velocity would be in m/s, not in/s or mm/hr, etc. Consistency is important.)
Any other issues may be coming from somewhere else...
Old   June 30, 2011, 02:34
Fernando
fher1608 is on a distinguished road
In fluent you can define the velocity inlet with magnitude and direction, son you can leave the geometry as it is and change the flow (projecting the speed). That is how I change the AOA
fher1608 is offline   Reply With Quote
Old   August 5, 2011, 09:22
Karthik
fher1608: so u ask me to give velocity components instead of changing the angle of attack of the model...... thn can u tell me how to evaluate the exact lift and drag forces acting on the model in fluent or ICEMCFD
Old   August 5, 2011, 09:23
Default lift and drag forces
Karthik
Old   August 5, 2011, 10:31
Fernando
In fluent you can define the projection of the forces. I mean, in monitors you can choose the direction of the drag, and also the lift, so the Cl and Cd calculated will be in that direction. Thats the way I do it and it's easier than changing the geometry
cfx airfoil mesh, changing angle of attack, drag force, icem, nacaairfoil
CFX convergence problem simulating ogive-cylinders at varied angle of attack jdacosta CFX 6 February 25, 2015 22:42
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
introducing angle of attack on ICEMCFD HEXA icem beginner CFX 2 December 24, 2008 12:00
introducing angle of attack on ICEMCFD HEXA icem beginner FLUENT 2 December 6, 2008 16:34
angle of attack kiran FLUENT 0 September 10, 2004 09:18
