Strange ANSYS Meshing 13.0 Problem
Old   June 17, 2011, 08:30
Default Strange ANSYS Meshing 13.0 Problem
Bruno Beban
brunob is on a distinguished road
i have been using icem and cfx a lot, but i am new to ansys meshing software. On the project I am working on we have decided to do some simulations with fluent and also to use new cut cell feature implemented in ansys 13.0 since it seems quite interesting. So, I have created my geometry in icem and exported it in .iges file format. I imported then geometry using ansys workbench and started ANSYS meshing 13. Everything seems working, but problem is that there is no CutCell feature in the Details of "Mesh" tree.
I also read about CutCell workflow in Help, and set prerequisites as it is described there: Physics Preference-CFD, Solver Preference-Fluent.
Are this only prerequisites, since I can't see CutCell feature at all, or there are some other?
Thanks in advance!
Best regards,
Bruno
brunob is offline   Reply With Quote
Old   June 18, 2011, 21:26
Default Global Cutcel is in the Mesh Details Panel.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Hey Bruno...
Unlike the other methods that operate on individual parts, Cut Cel is a global method (at 13.0 anyway)...
So you can't insert a method as you do for PI tetra or something like that.
However, when you have your mouse on the Mesh branch of the tree, you can find an option to use Cutcell in the Mesh Details Panel...
Best regards,
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   June 21, 2011, 05:05
Bruno Beban
Hey Simon,
thank you for the reply. Since I was using german language in ansys, CutCell was "translated" as AssemblyMeshing...completely wrong.
Best regards
Bruno
Old   June 21, 2011, 21:03
PSYMN's Avatar
Simon Pereira
Interesting that it would try to translate "Cutcel" at all...
You should certainly be able to insert MultiZone...
Right click on mesh to insert a method
Then in the details panel, you should be able to select the geometry and apply the method to it.
Then there is a "Method" field that defaults to "Automatic". Use the pulldown and change it to MultiZone...
Other details should appear...
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 23:04
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 01:43
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
Hexa Block meshes in ANSYS Meshing? siw ANSYS Meshing & Geometry 3 July 31, 2009 11:40
