[ICEM] Mesh within a mesh
Old   June 10, 2011, 01:29
Question Mesh within a mesh
N/A
cp_jef is on a distinguished road
Hi ANSYS Gurus,
I am planning to use ICEM CFD to mesh a cold plate with embedded fluid serpentine channels. First, the channels will be meshed intricately, and then the metal body. The outer metal body will be meshed in a simple manner using a bounding 3d block; which will also include the channel volume. Will the internal detailed mesh overwrite the outer coarse mesh in the channel sections? If so, there will be no need to mesh both bodies intricately.
Thanks,
John
cp_jef is offline   Reply With Quote
blocking, complex, hexa, serpentine
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 11:40
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 02:10
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
