[ANSYS Meshing] Huge Mesh generation.
Old   June 5, 2011, 21:36
Unhappy Huge Mesh generation.
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
Hi Everyone.
I have made a model in Ansys workbench designer, and attempted to make mesh on it. Since the expected mesh is about 4M elements the system couldn't handle it and stopped working. the Intersting part was even I had to restart the system.
I tried doing the same mesh with just reducing the number to 400K ( reducing the number of divisions in length) and it can make my mesh. I also can make this mesh on Gambit with 4M cells and no problem.
The question is , is it possible to run Ansys mesh generator in parallel mode, so that It divides the process between some processors and some more RAM?
If it is possible how, and If you know where to read about it, please tell me.
Yours.
SAHM
sahm is offline   Reply With Quote
Old   June 6, 2011, 12:42
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I think the problem is something other than mesh count... I personally know users who have generated 40 million cells in ANSYS Meshing (on a 64 bit machine), and routinely users generate in the 10 to 20 million cell range.
As for parallel meshing... that is algorithm specific.
Algorithms such as MultiZone, PI Tetra, Uniform QUAD and POST Prism can use shared memory parallel. Others, such as Patch conforming tetra, can not (yet).
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   June 7, 2011, 11:46
sahm's Avatar
Seyyed Ali H.M.
Dear Simon,
Thanks for you comment. As I said when I decrease the number in length it is fine with meshing, and every thing else is kept the same, but when I increase it, this happens, and as I said even the computer crashes, so I think it is not my fault. but my computers fault. The reason I asked for parallel was I wanted to distribute the process so that the faulty part of the computer doesn't come into action. But thanks to your comment, I will try again and see if I did something wrong.
Right now I'm running some cases with Fluent, which are time consuming, and If I try meshing with Ansys and the computer crashes, I will lose my Fluent jobs. but I think I can try it on another computer.
Thanks again.
SAHM
Old   June 7, 2011, 13:48
PSYMN's Avatar
Simon Pereira
Sorry, i can't identify the problem from here... Good luck with it.
Also, you could try tech support...
Techsupp@ANSYS.com
or check the website for a phone number or get help thru the customer portal...
Old   June 9, 2011, 20:08
ahasan1 is on a distinguished road
Dear All,
I think this is the right place to ask my question. I am trying to transfer ANSYS mesh file to FLUENT. I am wondering either I can do that. Please let me know.
Thanks.
Originally Posted by sahm View Post
Dear Simon,
Thanks again.
ahasan1 is offline   Reply With Quote
Old   June 9, 2011, 21:49
PSYMN's Avatar
Simon Pereira
Please be more specific... What extension is the file you currently have?
Do you have access to ICEM CFD?
Old   June 11, 2011, 00:54
Thank you for your reply. I have made a drawing of a simple square. Then I have meshed it. Now, I am trying to transfer this meshed flie to FLUENT. I have found that I need to make .msh file by ANSYS to work in FLUENT. However, I have failed to make .msh file by ANSYS. Please let me know how I can make it.
I do not have ICEM CFD. I have only ANSYS and FLUENT.
Old   June 12, 2011, 19:39
PSYMN's Avatar
Simon Pereira
ANSYS Prep7? ANSYS Meshing in Workbench? What kind of file are you outputting? An ANSYS input deck (*.in) or an ANSYS CDB file?
In Workbench, you should be able to connect a Fluent system directly, or you could export a Fluent MSH file...
ansys, gambit, mesh
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
mesh generation for in-cylinder fluent simulation hennas ANSYS Meshing & Geometry 2 May 31, 2011 16:08
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 14:47
