February 2, 2013, 10:49 |
#21 |
alireza
Rep Power: 16 |
Hi guys.
I'm modeling a complicated domain consisting of more than 12-13 million cells in Gambit. The number of volumes in the domain exceeds 3000 vols. I'm working on a 8-core CPU +24GB RAM+ win xp 64 bit + Gambit 2.4.6 (I think it's a 32 bit version) and EXCEED 13. I should copy some volumes to create whole domain. After reaching the grid number to about 10 mln, while I want to save the dbs file, the gambit terminates suddenly with a runtime error. The last line in the trn file is some thing like this: ERROR: Unable to read 94371840 bytes of data from descriptor 5, instead 0 bytes were read. Does any body have any idea regarding my problem? |
February 4, 2013, 01:54 |
#22 |
Maxime Perelli
Rep Power: 41 |
for windows, I believe there is no 64bit version of gambit.
You may try to create 2 dbs files, and then export 2 *.msh files. Then you can try to append mesh files within fluent
In memory of my friend Hervé: CFD engineer & freerider |
Gambit Startup Window | Jay Shim | FLUENT | 2 | February 12, 2015 14:05 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Generating big meshes with GAMBIT on NT | Andrew Ooi | FLUENT | 12 | February 2, 2000 22:26 |
