[ICEM] Wrong Prism Direction
Old   May 23, 2011, 09:16
Default Wrong Prism Direction
Max
max3.2 is on a distinguished road
Hi guys,
I'm tying to mesh a duct flow with ICEM Tet and 1 prism wall layer which I then want to split up. This is no problem so far. But when i split the layer to set an initial height, the initial height is set at the volume side, not the wall side. i have done prism mesh before, but never had this error. my material point is inside the volume(tet works perfectly). is there a way to turn direction for prism layers?
regards
max
max3.2 is offline   Reply With Quote
Old   May 24, 2011, 07:45
jeevan kumar
jeevankumarb is on a distinguished road
please can you post some images to better understand your problem
jeevankumarb is offline   Reply With Quote
Old   May 24, 2011, 09:53
Max
I will do later, cant acces my server atm.
EDIT:
There we go. Pic 1 overview, Pic 2 prism front view, Pic 3 splitted view. Problem: The thinner Prism are at the Flow side, but they should be at wall side...
Hope this helps
regards
Max
Old   June 14, 2011, 01:45
Smile
A-Vdia
ayush is on a distinguished road
Hey max, if i understood your problem properly, it is just that the gap between the initial height and the final specified prism height is not sufficient enough for the number of layers you want to grow. Try computing the Height ratio, it should be less than 1. So simply reduce the number of layers to get that ratio upto 1, and then later split the prisms to get your requisite layers.
ayush is offline   Reply With Quote
Old   June 19, 2011, 17:04
Max
Hmm thanks but i think i meant something else. As you can see, the growth ratio and initial height is right, if the wall (where the boundary layer is i want to resolve) would be on the right (in the picture above). but it is on the left, so theres the problem.
(I already changed to a block mesh. but still im interested in finding my mistake)
regards
max
Old   August 16, 2011, 23:34
Prakash Paudel
Prakash.Paudel is on a distinguished road
edit mesh ; move nodes; redistribute prism should do the trick
Prakash.Paudel is offline   Reply With Quote
Old   August 19, 2011, 06:54
Max
thank you. Since i used another mesh, I evaded this problem. But i tested it and it worked!
Old   August 20, 2011, 21:09
Default Defect... Fixed.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, sorry, we screwed it up at 13.0
When you split prism, it does it in reverse order so the fattest layer is on the inside...
We had redone the split prism (enhanced it in a bunch of ways with a whole new more flexible algorithm) and we screwed that one thing up.
The fix is to go one more step to Edit mesh => Move nodes => Redistribute Prism. That will sort you out.
This problem was corrected for 14.0, due out later this year.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
udf error srihari FLUENT 1 October 31, 2016 15:18
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 08:06
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 15:56
ICEM - Prism Tool Problem carpe85 CFX 0 February 10, 2009 13:25
Icemcfd: Preventing prism inflation collisions? Joe CFX 1 July 31, 2007 10:13
