[ANSYS Meshing] Mesh elements inside turbine blade
Old   May 11, 2011, 15:59
Default Mesh elements inside turbine blade
Eoin
eoinsturbine is on a distinguished road
I ran into an annoying problem when trying to mesh my wind turbine blade inside my flow domain. I repeatedly obtain mesh elements inside a part of my blade upon applying an automesh. I've rebuilt the blade several times and I still get the same problem. I have the file to hand if anyone would be willing to be so kind as to have a quick look at it. Maybe a fresh pair of eyes could see what it is that I'm overlooking. I've attached a photo of the basic setup. It features a inner semi cylinder encompassing the blade which will roatate with the blade. The outer semicylinder should remain stationary. A velocity inlet boundary condition will be applied and an outflow opposite to this.
Thanks,
Eoin
eoinsturbine is offline   Reply With Quote
Old   May 12, 2011, 08:57
zhao xin
zxin is on a distinguished road
Are you sure that you have suppressed or deleted the wind turbine body?
zxin is offline   Reply With Quote
Old   May 15, 2011, 12:44
Eoin
I've tried that but it seems to be a geometry error in the turbine. I created the turbine by joining airfoil shapes using surfaces. On close inspection, there appears to be very small holes in the geometry so I rebuilt it a couple of times and tried altering the tolerance settings in the geometry repair window. I also rebuilt the turbine using pro engineer but was also unsuccessful. Any ideas?
Thanks
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 11:18
Meshing a 3D, tapered and twisted blade with Gambit-TGrid teskio ANSYS Meshing & Geometry 0 July 3, 2009 11:36
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
