Tgrid makes FLUENT contours messed up??
Old   April 4, 2011, 20:50
Default Tgrid makes FLUENT contours messed up??
me3840 is on a distinguished road
Hey guys,
I just got a copy of Tgrid 64bit (ANSYS 13), but when I mesh things with it and run them, then plot the contours in FLUENT12, the body of whatever I'm modeling isn't "solid" - that is, you can see the part of the car facing you and the part that should be hidden at the same time? This doesn't occur when I use Tgrid 32bit (from ANSYS 12), but then I'm limited to 4GB of memory to make meshes!
Any advice?
me3840 is offline   Reply With Quote
Old   May 13, 2011, 08:26
udayrg is on a distinguished road
I feel the problem is not with the mesh. The problem would be with the graphic's Setting in Fluent.
udayrg is offline   Reply With Quote
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
Contours of density gradient in fluent 5? Ricky Wong FLUENT 3 May 19, 2015 02:39
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
