March 31, 2011, 04:58 |
[DesignModeller]Patterning with zero spacing
Rep Power: 15 |
I tried to imprint a square on solid block and patterning the face 10 times into the x-direction.
However, it does not allow me to have a zero spacing between each imprint. The spacing causes lots of meshing problems thereafter. Is it possible to pattern without this spacing? Or can other Ansys-friendly CAD software able to do this? |
April 2, 2011, 11:18 |
Simon Pereira
Rep Power: 47 |
A zero pattern doesn't make any sense... that would just copy over its self.
The spacing is center to center, not the gap between... If you mean the squares should be right next to each other (zero gap) then the spacing should be the same as the edge size of the square or the distance between centers...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
April 3, 2011, 10:16 |
Rep Power: 15 |
Yes i meant zero spacing. DM doesn't allow that. Have you tried?
Gridgen node spacing | Vincent | Pointwise & Gridgen | 4 | August 7, 2016 18:33 |
element size control in ICEM (line & face spacing) | Sam | CFX | 0 | January 28, 2008 14:28 |
Using grid spacing calculator for laminar flow | CH | Main CFD Forum | 0 | November 5, 2006 01:02 |
small node spacing | Gary Holland | FLUENT | 13 | June 10, 2005 11:06 |
Spacing Factor | Alexandre | Siemens | 1 | December 21, 2002 04:21 |
